Has anyone run Hailo-8 successfully on Ubuntu 26.04 x86_64?
Hi all,
We are looking at using a Hailo-8 PCIe accelerator for continuous YOLO video inference on an x86_64 TetherBox/server running Ubuntu 26.04 LTS.
I found a successful Ubuntu 26.04 report for Raspberry Pi / ARM64, but have not found an equivalent x86_64 deployment yet. Has anyone installed and run Hailo-8 successfully on Ubuntu 26.04 x86_64?
If so, could you please share:
  • HailoRT and PCIe driver versions
  • Kernel version
  • Whether you used the packaged installer or built the driver from source
  • Any issues with DKMS, TAPPAS, GStreamer, or YOLO inference
We are specifically interested in a production-style PCIe setup rather than a Raspberry Pi deployment. Thanks.
I’m having similar difficulty with Hailo-10H chips on PCIe modules on Ubuntu 26.
I’ve got four Hailo-10H PCIe modules in a quad M.2 extender card mounted in the primary GPU card slot (16x16) on Ryzen 9 iron, lspci reports them as Speed 8GT/s Width x4, so they got gas and are ready to fly.
I can compile ‘hailo-ai/hailort-drivers’ source at Github if I specify the ‘v5.3.0-hotfix-kernel-above-6-15’ branch and correctly place the AMD libraries. After installation, the kernel 7.0.0-38-generic loads the module with no complaints.
With that driver in place, I can compile the ‘hailo-ai/hailort’ github repo and get the utility, which correctly reports the cards with ‘scan’ and ‘fw-control identify’ sub-commands.
That’s all I’ve got so far, I can’t seem to figure out how to hook them up for use with Ollama or ComfyUI. I’m old school, this is really new stuff, and learning as fast as can (no time for definite articles!). Hope this helps.
I can definitely confirm that the OS sees four M.2 Hailo-10H modules when bolted into an Asus Hyper M.2 X16 Gen4 card and plugged into a motherboard slot that supports 4x4x4x4 bifurcation (on this motherboard it was only the GPU slot). On this machine, moving the GPU to another slot didn’t hurt the final rendering speed.
