I need the Hailo8 M.2 module schematic, I need to directly connect ic with processor, I have limited space as I can not connect module, so I need pcie pins of the Hailo8 ic to connect with processor and power pins as well.
Please Help !
Please Help !
Hey @VIVEK_KUMAR,
Could you take a look at the Hailo8 datasheet? You can find it at https://hailo.ai/developer-zone/documentation/ - just navigate to the hardware section and select Hailo8.
Thanks omria,
I got the datasheet and pins of Hailo8 but I didn’t get any reference design shematic of pcie based module. Please help me to find reference design for pcie communication or hailo8 m2 module schematic.
Please help !!
Hey @VIVEK_KUMAR,
We don’t publish full open reference design schematics for our PCIe modules (including the Hailo-8 M.2 or Mini-PCIe cards) in our public documentation. However, what we do provide should cover most integration needs:
What’s Available:
Module-level block diagrams - These show the high-level connections between the AI processor, memory, and PCIe lanes. Check out the System-Level Block Diagram in the Hailo-10H M.2 Key M module datasheet. While this is for the 10H, the PCIe interface wiring follows standard M.2 Key M NGFF specs and is identical across our M.2 modules.
Complete connector pinouts - Full pinout details for the M.2 Key M edge connector (PCIe Gen-3 x4), including all PET/n, PER/n, REFCLK, PERST#, CLKREQ#, PETWAKE#, and CONFIG pins. See Table 2 “PCIe Connector Pinout” on page 8 of the Hailo-10H datasheet - same pin assignments apply to Hailo-8 M.2 modules.
Mechanical specifications - Detailed mechanical drawings and board layout outlines showing component keep-out zones and mounting positions. Check Figures 2 and 3 on pages 9-10 of the same datasheet.
This should give you everything needed for proper host board integration. Let me know if you need clarification on any specific aspect of the interface!
Hi @omria,
Thanks for your reply !
From the points you have provided is ok for PCIe connecion but I didn’t able to figure out from block diagram that how to give power sequence, reset and clock circuit.
Also in block diagram eeprom is connected.
Iam confused and I need reference design atleast to interface the IC with processor.
Please help !!
