I’m looking for people from the Hailo community and Hailo officials to rewrite the C++ to Rust. I’m unsure where to start, but I’ll research and re-read the HailoRT and Tapps-Core source code to better understand the starting point.
Please send me a dm if you are interested.
Thank you for being a pro-active community and enjoy your weekend!
Hi @nino
Thanks for bringing this up! If you’re looking to rewrite C++ into Rust or call C++ from Rust, here are some tools to consider:
cxx crate: Best for safe, high-level Rust-C++ interop.
bindgen: Automatically generates Rust bindings from C++ headers (C ABI).
cpp crate: Embed C++ directly into Rust for more control.
FFI: For manual, low-level integration.
Simple object detection is working but now I want to make reading the hef parameters dynamic so users don’t need to know the names of all the input and output streams, their configs,…
I am trying to make a hef_manager that can read hefs and extract this info. Unfortunately I am stuck with the proto not being able to read the hef:
Running target/debug/hef_cli hef/centernet_resnet_v1_18_postprocess.hef
Parsed Magic: 0x01484546
Parsed Version: 1
Parsed Proto Size: 1912603
Parsed Header: HefHeader { magic: 21513542, version: 1, hef_proto_size: 1912603, details: V1 { crc: 3828573467, ccws_size: 10932176, reserved: 0 } }
Calculated Proto Offset: 10932200
Proto Data Size: 1912603, Offset: 10932200, Requested Size: 1912603
Proto data written to: proto_dump.pb.cc
Parsed Version: 1
Error parsing HEF file: Proto decode error at offset 10932200 with size 1912603: failed to decode Protobuf message: ProtoHefHef.network_groups: invalid wire type: SixtyFourBit (expected LengthDelimited)
