Klaus
June 2, 2026, 8:10am
Installed HailoRT 4.23 on a RPI 5 with Raspbian Lite 64bit Debian 13.5. Using cli HailoRT discovered the Hailo8. After reboot of the RPI5 HailoRT can no longer discover the Hailo8 chip.
After installation:
Identifying board
Control Protocol Version: 2
Firmware Version: 4.23.0 (release,app,extended context switch buffer)
Logger Version: 0
Board Name: Hailo-8
Device Architecture: HAILO8
After reboot no answer from “hailortcli fw-control identify”.
What can we do?
Thanks for your help.
Klaus
June 2, 2026, 8:39am
Sorry for posting this , since after some work with “Ask AI” we developed the following solution:
sudo apt install --reinstall hailort-pcie-driver
sudo reboot
hailo_pci/4.23.0, 6.12.75+rpt-rpi-2712, aarch64: installed
Identifying board
Logger Version: 0
Board Name: Hailo-8
sudo reboot
hailortcli fw-control identify >> Same results as before, i.e. it seems the problem is fixed.
Should have used “Ask AI” immediately.
