Hailomz Segmentation Fault
does anyone know how to fix this or experience this error?
Hey @Leynard_Villagracia,
Yeah, you’ll need a GPU to run performance mode during compilation, but it sounds like you’ve got a different issue going on here.
Can you share the hailort logs or the full CMD output? Just seeing “seg fault” doesn’t give me much to work with - need to see what’s actually happening before it crashes.
Hopefully once I can see the logs I should be able to point you in the right direction.
where and how can I see the hailort logs?
