Hailo10H with Raspberry Pi 5
Does the Hailo‑10H support Raspberry Pi 5, including connection via M.2?
Hey @Eden_Ben_Meshi,
Just so you know, the Hailo-10H supports both ARM and X86 host machines, same as the Hailo8. So yeah, it should work fine with the Raspberry Pi.
Hi omria,
Do you have any recommendations for Raspberry Pi M.2 cases and related setup SOPs or user guides? I’m planning to run Ollama on a Raspberry Pi 5 and would like to leverage Hailo‑10H for acceleration.
Have a look at the following post I wrote. It also shows a setup of a Raspberry Pi 5 with a Geekworm M.2 HAT and a Hailo-10 module.
Hailo Community - How can I connect a Hailo-10H to my PC or laptop?
I haven’t seen a perfect-fit case for this setup yet. It’s more of a lab test configuration because the PCBs are stacked on top of each other, so you would likely need to create a custom enclosure if you want it fully enclosed and still provide good ventilation to the CPU.
This post perfectly answers what I wanted to know — thank you! If, in the future, a vendor can provide a case that is compatible with the Hailo-10 M.2 and ensures good thermal performance and stability, I believe it would be a great boost for running LLMs on edge AI devices.”
