I am currently trying to test an LLM model by connecting a Hailo-10h module to the Novatek NT98336 board.
Previously, I had successfully used a Hailo-8 module on the same NT98336 board without any issues, but when I connected the Hailo-10 module to the same board, I observed that the PCI link disconnects after firmware loading.
Below is the kernel log after executing insmod hailo1x_pci.ko on the NT98336 board:
[ 22.772418] hailo1x: Init module. driver version 5.1.1
[ 22.777964] hailo1x 0000:01:00.0: Probing on: 1e60:45c4...
[ 22.783491] hailo1x 0000:01:00.0: Probing: Allocate memory for device extension, 11240
[ 22.791422] hailo1x 0000:01:00.0: enabling device (0000 -> 0002)
[ 22.797434] hailo1x 0000:01:00.0: Probing: Device enabled
[ 22.803027] hailo1x 0000:01:00.0: Probing: mapped bar 0 - 000000007b2b7bde 16384
[ 22.810465] hailo1x 0000:01:00.0: Probing: mapped bar 2 - 00000000242ab86d 4096
[ 22.817806] hailo1x 0000:01:00.0: Probing: mapped bar 4 - 000000000db228cf 16384
[ 22.825198] hailo1x 0000:01:00.0: Probing: Setting max_desc_page_size to 4096, (PAGE_SIZE=4096)
[ 22.833893] hailo1x 0000:01:00.0: Probing: Enabled 64 bit dma
[ 22.839635] hailo1x 0000:01:00.0: Probing: Using specialized dma_ops=arm64_swiotlb_dma_ops
[ 22.847892] hailo1x 0000:01:00.0: Disabling ASPM L0s
[ 22.852943] hailo1x 0000:01:00.0: Manually disabled ASPM L0s
[ 22.859056] hailo1x 0000:01:00.0: Writing file hailo/hailo10h/customer_certificate.bin
[ 22.870300] hailo1x 0000:01:00.0: File hailo/hailo10h/customer_certificate.bin written successfully
[ 22.879347] hailo1x 0000:01:00.0: Writing file hailo/hailo10h/scu_fw.bin
[ 22.952096] hailo1x 0000:01:00.0: File hailo/hailo10h/scu_fw.bin written successfully
[ 23.021771] hailo1x 0000:01:00.0: Board SKU-ID is: 1
[ 23.026736] hailo1x 0000:01:00.0: Writing file hailo/hailo10h/u-boot-1.dtb.signed
[ 23.043340] hailo1x 0000:01:00.0: File hailo/hailo10h/u-boot-1.dtb.signed written successfully
[ 23.145430] hailo1x 0000:01:00.0: Reading firmware file hailo/hailo10h/u-boot-spl.bin
[ 23.157839] hailo1x 0000:01:00.0: Reading firmware file hailo/hailo10h/u-boot-tfa.itb
[ 23.165803] hailo1x 0000:01:00.0: Reading firmware file hailo/hailo10h/fitImage
[ 23.665176] hailo1x 0000:01:00.0: Reading firmware file hailo/hailo10h/image-fs
[ 26.741025] hailo1x 0000:01:00.0: Firmware file programmed successfully
[ 26.747675] hailo1x 0000:01:00.0: Firmware file index 0 programmed successfully
[ 26.764240] hailo1x 0000:01:00.0: Firmware file programmed successfully
[ 26.770843] hailo1x 0000:01:00.0: Firmware file index 2 programmed successfully
[ 26.834330] hailo1x 0000:01:00.0: Firmware file programmed successfully
[ 26.840935] hailo1x 0000:01:00.0: Firmware file index 3 programmed successfully
[ 26.848245] hailo1x 0000:01:00.0: Firmware batch programming completed for stage 2
[ 26.972129] hailo1x 0000:01:00.0: vDMA transfer completed, triggering boot
[ 27.527638] hailo1x 0000:01:00.0: SOC Firmware Batch loaded successfully
[ 27.534341] hailo1x 0000:01:00.0: Firmware loaded in 4675 ms
[ 27.578187] PCIE TOP ISR: link down
[ 27.578572] hailo1x 0000:01:00.0: Probing: Added board 1e60-45c4, /dev/hailo0
[ 27.700622] wait_speed_change: elps 27946167 ns, resolution 83 ns (start 7617553424160, end 7617581370327)
[ 27.710344] wait_speed_change: link sts 0xa0130000
I don’t know what differences between Hailo-8 and Hailo-10 could cause this issue. Are there any specific things I should check?
