Hailo10H Compiler: Layer Support for Input Tensors with Large Dimension Sizes
While compiling EfficientLoFTR using Hailo AI SW Suite 2026-01, I have encountered the following error, when compiling the reshape operation:
[1, 6400, 12, 12] → [1, 6400, 1, 144] ≈ [1, C·F, H, W] → [1, C·F, 1, H·W] — fails
[error] eloftr Multi Context Partition Failed (duration: 0s)
[error] eloftr Partition and Allocation Failed (duration: 34s)
[error] eloftr Compilation Failed (duration: 34s)
No successful assignments: format_conversion68_defuse_width_feature_reshape errors:
Agent infeasible
failed on kernel validation: LCUReshapeWidthFeaturesTranspose does not support
    two subclusters with one apu in current arch
failed on kernel validation: format_conversion68_defuse_width_feature_reshape
    has 2 APUs but max allowed is 1
As the reshape op I have implemented is supported by the DFC compiler according to the Guidelines (5.5.29). I wonder this error lies in the high size of the tensor in certain axis. The same error: “2 APUs but max allowed is 1”, showed up for a 2d conv with similarly sized tensor.
Thus my questions are:
  1. Does the problem lays in the size of the tensors or is it related to the way I am defining ops (given that the model parses, and optimizes successfully)?
  2. Would it be possible to allows multiple APUs for the same memory buffer?
  3. How would you resolve the error?
Hi @user976,
I noticed both threads (Hailo10H Data Flow Compiler Error: Spatial Reshape Infeasible) are related to the same EfficientLoFTR compilation, so I’ll address them together.
Both errors are compiler allocation failures where the intermediate tensor sizes (the 4800×4800 similarity matrix from matmul33, and the [1, 6400, 12, 12] reshape) exceed what the hardware can map for those specific operations at that resolution.
Since you confirmed that compilation succeeds at lower resolutions, you might try reducing the input to an intermediate size (e.g. 416×416 or 512×512) and see where the threshold is.
Alternatively, you could set end_node_names during parsing to cut the graph before the problematic layers and handle those operations in CPU post-processing.
