The led is orange.
$ hailortcli fw-control identify
show blank. lspci doesnt show the device
$ lspci
0002:00:00.0 PCI bridge: Broadcom Inc. and subsidiaries BCM2712 PCIe Bridge (rev 30)
0002:01:00.0 Ethernet controller: Raspberry Pi Ltd RP1 PCIe 2.0 South Bridge
the pcie seems to be down
$ dmesg | grep -i pcie
[ 0.000000] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0 numa=fake=8 system_heap.max_order=0 iommu_dma_numa_policy=interleave smsc95xx.macaddr=2C:CF:67:B5:B4:23 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000 console=ttyAMA10,115200 console=tty1 root=PARTUUID=51f2d75f-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=JP
[ 0.029125] /axi/pcie@1000110000: Fixed dependency cycle(s) with /axi/pcie@1000110000
[ 0.029162] /axi/pcie@1000120000/rp1/i2c@80000/ov5647@36: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/csi@128000
[ 0.029172] /axi/pcie@1000120000/rp1/i2c@88000/ov5647@36: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/csi@110000
[ 0.029197] /axi/pcie@1000120000/rp1/csi@110000: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/i2c@88000/ov5647@36
[ 0.029204] /axi/pcie@1000120000/rp1/csi@128000: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/i2c@80000/ov5647@36
[ 0.029269] /axi/pcie@1000110000: Fixed dependency cycle(s) with /axi/pcie@1000110000
[ 0.029363] /axi/pcie@1000120000/rp1/i2c@80000/ov5647@36: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/csi@128000
[ 0.029374] /axi/pcie@1000120000/rp1/i2c@88000/ov5647@36: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/csi@110000
[ 0.029401] /axi/pcie@1000120000/rp1/csi@110000: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/i2c@88000/ov5647@36
[ 0.029409] /axi/pcie@1000120000/rp1/csi@128000: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/i2c@80000/ov5647@36
[ 0.416848] brcm-pcie 1000110000.pcie: host bridge /axi/pcie@1000110000 ranges:
[ 0.416853] brcm-pcie 1000110000.pcie: No bus range found for /axi/pcie@1000110000, using [bus 00-ff]
[ 0.416861] brcm-pcie 1000110000.pcie: MEM 0x1b80000000..0x1bffffffff -> 0x0080000000
[ 0.416865] brcm-pcie 1000110000.pcie: MEM 0x1800000000..0x1b7fffffff -> 0x0400000000
[ 0.416870] brcm-pcie 1000110000.pcie: IB MEM 0x0000000000..0x0fffffffff -> 0x1000000000
[ 0.416874] brcm-pcie 1000110000.pcie: IB MEM 0x1000131000..0x1000131fff -> 0xfffffff000
[ 0.418234] brcm-pcie 1000110000.pcie: PCI host bridge to bus 0001:00
[ 0.418254] pci 0001:00:00.0: [14e4:2712] type 01 class 0x060400 PCIe Root Port
[ 0.761409] brcm-pcie 1000110000.pcie: link down
[ 0.766177] pcieport 0001:00:00.0: PME: Signaling with IRQ 39
[ 0.766230] pcieport 0001:00:00.0: AER: enabled with IRQ 39
[ 0.766432] brcm-pcie 1000120000.pcie: host bridge /axi/pcie@1000120000 ranges:
[ 0.766436] brcm-pcie 1000120000.pcie: No bus range found for /axi/pcie@1000120000, using [bus 00-ff]
[ 0.766442] brcm-pcie 1000120000.pcie: MEM 0x1f00000000..0x1ffffffffb -> 0x0000000000
[ 0.766446] brcm-pcie 1000120000.pcie: MEM 0x1c00000000..0x1effffffff -> 0x0400000000
[ 0.766451] brcm-pcie 1000120000.pcie: IB MEM 0x1f00000000..0x1f003fffff -> 0x0000000000
[ 0.766455] brcm-pcie 1000120000.pcie: IB MEM 0x0000000000..0x0fffffffff -> 0x1000000000
[ 0.766458] brcm-pcie 1000120000.pcie: IB MEM 0x1000130000..0x1000130fff -> 0xfffffff000
[ 0.767696] brcm-pcie 1000120000.pcie: PCI host bridge to bus 0002:00
[ 0.767711] pci 0002:00:00.0: [14e4:2712] type 01 class 0x060400 PCIe Root Port
[ 0.869413] brcm-pcie 1000120000.pcie: clkreq-mode set to default
[ 0.869427] brcm-pcie 1000120000.pcie: link up, 5.0 GT/s PCIe x4 (!SSC)
[ 0.869449] pci 0002:01:00.0: [1de4:0001] type 00 class 0x020000 PCIe Endpoint
[ 0.877494] pcieport 0002:00:00.0: enabling device (0000 -> 0002)
[ 0.877512] pcieport 0002:00:00.0: PME: Signaling with IRQ 40
[ 0.877554] pcieport 0002:00:00.0: AER: enabled with IRQ 40
[ 0.881990] /axi/pcie@1000120000/rp1/i2c@80000/ov5647@36: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/csi@128000
[ 0.882071] /axi/pcie@1000120000/rp1/i2c@88000/ov5647@36: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/csi@110000
[ 0.882425] /axi/pcie@1000120000/rp1/i2c@88000/ov5647@36: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/csi@110000
[ 0.882439] /axi/pcie@1000120000/rp1/csi@110000: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/i2c@88000/ov5647@36
[ 0.882504] /axi/pcie@1000120000/rp1/i2c@80000/ov5647@36: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/csi@128000
[ 0.882518] /axi/pcie@1000120000/rp1/csi@128000: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/i2c@80000/ov5647@36
[ 3.345849] /axi/pcie@1000120000/rp1/csi@128000: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/i2c@80000/ov5647@36
[ 3.345875] /axi/pcie@1000120000/rp1/i2c@80000/ov5647@36: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/csi@128000
[ 3.349154] /axi/pcie@1000120000/rp1/csi@110000: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/i2c@88000/ov5647@36
[ 3.349186] /axi/pcie@1000120000/rp1/i2c@88000/ov5647@36: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/csi@110000
[ 3.579439] rp1-cfe 1f00110000.csi: found subdevice /axi/pcie@1000120000/rp1/i2c@88000/ov5647@36
[ 3.588047] rp1-cfe 1f00128000.csi: found subdevice /axi/pcie@1000120000/rp1/i2c@80000/ov5647@36
I have check the connection and it is indeed connected properly (the side of the cable that have letter is on top)
I also have reinstall hailo-all multiple, but have no luck.
It was previously work, maybe 1 month ago, but I left it and only come back to continue recently.
