So this is really more of a bug report than anything else, but I’m not really sure where else to share it.
I’ve been trying to compile the model in the attached HAR file for the Hailo 8, and I can get parsing and optimization to work, but the final compilation to HEF always fails. The compiler consistently crashes with a weird error:
[info] Current Time: 13:01:14, 10/15/25
[info] CPU: Architecture: x86_64, Model: 13th Gen Intel(R) Core(TM) i7-13700K, Number Of Cores: 24, Utilization: 5.3%
[info] Memory: Total: 31GB, Available: 11GB
[info] System info: OS: Linux, Kernel: 6.9.3-76060903-generic
[info] Hailo DFC Version: 3.33.0
[info] Running `hailo compiler --hw-arch hailo8 ../git/foundation_model/plantsam_bc2_multi_modal_full_renamed_quantized_model.har`
[info] Compiling network
/usr/include/c++/9/bits/stl_vector.h:1120: std::vector<_Tp, _Alloc>::reference std::vector<_Tp, _Alloc>::front() [with _Tp = long unsigned int; _Alloc = std::allocator<long unsigned int>; std::vector<_Tp, _Alloc>::reference = long unsigned int&]: Assertion '__builtin_expect(!this->empty(), true)' failed.
I’ve been flummoxed by this for awhile now, but by using the remove_nodescript feature I think I’ve finally narrowed it down to a single upscaling head at the end of the model. For reference, the attached script, which disables all the nodes in this head, fixes the issue I’m having. I just wanted to report this as a likely bug in the compiler. Thanks!
