Hailo compilation fails with BackendAllocatorException / concat14 Agent infeasible on ONNX detection model
I am trying to compile an ONNX object detection model with Hailo, and I am stuck at the compilation stage.
Environment
  • Hailo environment: hailodfc
  • ONNX exported from MMDetection / RTMDet-style model
Current status
  • ONNX parsing works
  • DFL optimization also succeeds
  • Failure happens during compilation / mapping
Error
[info] Successfully built optimization options - 7s 239ms
[error] Mapping Failed (allocation time: 7s)
No successful assignments: concat14 errors:
        Agent infeasible
[error] BackendAllocatorException: Compilation failed: No successful assignments: concat14 errors:
        Agent infeasible
Important detail
In my ONNX graph, I do not see a node literally named concat14.
The ONNX concat nodes are named like:
  • /Concat_4
  • /Concat_6
  • etc.
So I assume concat14 is an internal Hailo-translated node name rather than the original ONNX node name.
What I already checked
  • Parsing issue is resolved
  • End nodes were corrected to match the ONNX node names
  • DFL optimization runs successfully
  • The problem only appears at compilation/mapping stage
My question
What does Agent infeasible on concat14 usually mean in practice?
I would like to know:
  1. How to identify which original ONNX concat corresponds to Hailo internal concat14
  2. Whether this usually indicates:
    • too large input resolution
    • too many channels at a concat
    • problematic neck/head structure
    • unsupported topology for mapping
  3. What is the recommended way to fix it:
    • reducing input size
    • changing end nodes
    • simplifying the ONNX graph
    • changing export settings
    • modifying the model architecture
Hi @gje_gje,
“Agent infeasible” means the Hailo compiler couldn’t map that concat layer onto the hardware - typically because the tensor dimensions at that point exceed what the HW can handle in a single operation.
To identify the node: Open the .har file’s model visualization (or run hailo profiler) - concat14 is the internal name assigned during parsing. It usually corresponds to the 14th concat encountered in graph traversal order.
Common causes might be input resolution too high or too many channels at the concat.
hello
I have a same problem
did you find any solution?
In my case, the issue seemed to be related to the post-processing part of the model.
From what I observed, the Hailo compiler failed during the mapping stage, possibly because some operations in the post-processing (especially concat-heavy parts or detection head logic) are harder to map or may become infeasible for allocation.
What worked for me
I tried cutting the model before the post-processing stage, keeping only the network up to the last convolution layers and removing the rest.
After doing this, the compilation succeeded.
In my case the model was YOLO-based, so if you are using a YOLO-like architecture, this issue might very well be related to the post-processing part as well.
