Newbie here, can anyone help me if the current version of hailo-apps–infra is compatible with Rpi5 with Hailo8L, as I’m having issue when executing below command:
1. Clone the repository
git clone GitHub - hailo-ai/hailo-apps-infra cd hailo-apps-infra
2. Run the automated installation script
./install.sh
Here’s the error I have got:
ion-0.4.1 tzdata-2025.2 uvicorn-0.35.0 websockets-15.0.1
ð§ Running post-install scriptâ¦
File “/home/json/hailo-apps-infra/venv_hailo_apps/bin/hailo-post-install”, line 7, in
sys.exit(main())
File “/home/json/hailo-apps-infra/hailo_apps/hailo_app_python/core/installation/post_install.py”, line 147, in main
post_install()
File “/home/json/hailo-apps-infra/hailo_apps/hailo_app_python/core/installation/post_install.py”, line 109, in post_install
handle_dot_env() # this loads the .env file if it exists
File “/home/json/hailo-apps-infra/hailo_apps/hailo_app_python/core/installation/set_env.py”, line 25, in handle_dot_env
print(f"\U0001f527 Creating .env file at {env_path}")
UnicodeEncodeError: ‘latin-1’ codec can’t encode character ‘\U0001f527’ in position 0: ordinal not in range(256)
