Hailo AI HAT+ PCIE expansion board compatibility
Hi all,
Will the Hailo AI HAT+ work with a particulare PCIE expansion PCB? we’ve lookd at the 52PI range which state they are not compatible with the Hailo HAT - Has anyone had any sucess with using the Hailo HAT with a particular brand of PCIE expansion pcb for the RPI5?
Thanks
The Hailo AI HAT+ is not designed to share the PCIe interface with other devices because the Raspberry Pi has only a single PCIe lane, whereas the Hailo-8 can utilize up to four lanes. As a result, the PCIe connection is already a bottleneck when running complex pipelines involving multiple models or multiple camera inputs.
I tested a third-party Raspberry Pi HAT with two M.2 slots and a built-in PCIe switch. However, the performance was poor and the system lacked stability.
If you’re considering using a second PCIe device for storage, I recommend using a USB 3.0-connected SSD instead, and reserving the PCIe lane exclusively for the Hailo accelerator.
Do you have another use case in mind?
Hi KlausK,
Thanks for replying.
We were hoping to use two PCIe devices on the Raspberry Pi 5. One being the AI HAT and the other a 5G modem.
The plan was to use a PCIe expansion HAT to allow us to connect both devices to the Pi.
Is this possible - and If so, do we know which PCIe expansion HAT(a) are compatible?
Thanks for your time
Matt.
I recommend looking into HATs that have two M.2 slots. This way, you can use a Hailo-8 M.2 module directly, rather than trying to adapt the AI HAT+.
Unfortunately, I can’t recommend a specific model, as I’ve only tested one that didn’t perform well.
For best possible performance, the HAT should use a PCIe Gen 3 switch.
Alternatively, I would recommend checking if the 5G modem can be connected via USB.
