I recently purchased a Hailo-8L M.2 AI accelerator module from Farnell and am experiencing an issue with device detection on my Dell OptiPlex 3000 Thin Client.
Hardware configuration:
Computer: Dell OptiPlex 3000 Thin Client
Motherboard: Dell 08FYG4, Revision A03
BIOS Version: 1.37.0 (July 22, 2026)
Operating System: Ubuntu 24.04.5 LTS
Kernel: 7.0.0-38-generic (x86_64)
Hailo Module: HM21LB1C2KAE (Hailo-8L, M.2 2230 A+E)
Connection: Internal M.2 WLAN slot (Key A/E)
Problem description:
The Hailo-8L module is physically installed in the M.2 WLAN slot, but it is not detected by the system at the PCIe enumeration level.
The lspci command shows only two PCIe endpoints:
Realtek Gigabit Ethernet Controller
Micron 2550 NVMe SSD
The Hailo device does not appear in lspci, and no corresponding PCIe root port is visible.
Troubleshooting already performed:
Verified that WLAN is enabled in the BIOS.
Tested PCIe ASPM settings (Auto and Disabled).
Checked PCIe enumeration using
lspci -nn,lspci -tv, andlspci -Dnn. -
Examined kernel messages using
dmesg. -
Confirmed that no Hailo device is detected.
Since the module is not detected at the PCIe level, I have not attempted to install the Hailo PCIe driver.
Questions:
Is the Hailo-8L HM21LB1C2KAE module known to be compatible with the Dell OptiPlex 3000 Thin Client or similar Intel Jasper Lake platforms?
What are the specific requirements for the PCIe signals
PERST#,CLKREQ#, and reference clock on the M.2 A+E interface? -
What is the maximum current consumption from the 3.3 V supply, including startup and transient peak current?
Are there any known BIOS, PCIe initialization, or power-management compatibility issues that could prevent PCIe enumeration?
Are there any recommended diagnostic procedures or hardware adapters that could help identify or resolve this issue?
I would appreciate your technical guidance on determining whether this is a platform compatibility issue or a possible hardware fault.
Thank you for your assistance.
