Setup
Device: Hailo-8 (M.2)
Hosts tested:
• CM4 carrier (PCIe Gen2 x1)
• PC x86_64 (PCIe Gen4 x1)
• Raspberry Pi 5 (default Gen2 x1 → forced Gen3 x1)
• HailoRT versions tested: 4.19 / 4.20 / 4.22 (same results)
• Model: ssd_mobilenet_v2.hef
• CPU load is low
PCIe info (lspci)
• CM4: LnkSta: Speed 5GT/s, Width x1 (Gen2 x1)
• PC: LnkSta: Speed 8GT/s, Width x1 (Gen3 x1)
• RPi5: Gen2 x1 by default; after pciex1_gen=3 → LnkSta: Speed 8GT/s, Width x1
Throughput / FPS (hailortcli)
• CM4 (Gen2 x1): ~75 FPS, Send ~162 Mbit/s (~20 MB/s)
• PC (Gen3 x1): ~126 FPS, Send ~271 Mbit/s
• RPi5: Gen2 x1 ~81 FPS → Gen3 x1 ~126 FPS
So bandwidth isn’t saturated (Gen2 x1 ≈ 492 MB/s), but latency/transaction overhead seems to limit feeding the device on CM4.
Questions:
• On CM4, is ~70–80 FPS a realistic ceiling for ssd_mobilenet_v2 at 300×300, or should I expect more?
• Any recommended HailoRT knobs to better “fill” the device on CM4?
• Is there any way to adjust PCIe parameters for the CM4, either through the Linux kernel or config.txt, to improve link efficiency?
• Are there any known kernel or firmware settings specific to CM4 that could help in this context?
• Is there any known CM4-specific limitations/patches for Hailo-8 that I should be aware of?
Happy to provide more logs if useful.
Thanks for any guidance or examples of configs that improved FPS on CM4!
Your numbers for the PC and RPi5 look fine. Since the CM4’s CPU is weaker, the gap compared to the RPi5 makes sense.
The HailoRT CLI will give you the upper limit of what you can expect in your application. If you need better performance you should check the Model Explorer in the Developer Zone for other potential models that you could use.
Hailo - Model Explorer Vision
For generic questions about the CM4, I recommend using the Raspberry Pi forums and ChatGPT.
With the introduction of the Raspberry Pi 5 and the Raspberry Pi AI HAT+ we have been focusing more on that platform.
I setup a Raspberry Pi 4 with a Hailo-8 and I get 783 FPS for the ssd_mobilenet_v2.hef from the Hailo Model Zoo using the hailortcli run command.
I’ve just set up a Raspberry Pi Compute Module 4 running Debian 13.1 with HailoRT 4.23.
When I run the command:
hailortcli run ssd_mobilenet_v2.hef
I get around 75 FPS.
Since my RPI4 doesn’t have a PCIe connector, I can’t test on a regular Raspberry Pi 4. Do you use a specific RPi4 model for your benchmarks?
Did you modify anything in the config.txt file (or elsewhere) on your target?
You mentioned achieving 783 FPS, which seems unusually high — even compared to what I see on a PC or a Raspberry Pi 5. Isn’t that a bit surprising?
Thanks in advance for your insights!
No, I used a Raspberry Pi 4 Compute Module on a Waveshare Mini Base Board. It looks like the setup I used for the following post a while ago.
Hailo Community - How can I connect a Hailo-8 to a Raspberry Pi 4?
The HEF file I used is compiled to a single context. You can download the HEF file from the Model Zoo GitHub page:
GitHub - Hailo Model Zoo - Hailo-8 Object Detection
When you build the model it will likely be compiled to multiple contexts unless you use the Hailo Dataflow Compiler Performance Mode. This method of compilation will require significantly longer time to complete. See Hailo Dataflow Compiler User Guide:
You can test whether a model is compiled to single or multi-context by running the following command:
hailortcli parse-hef ssd_mobilenet_v2.hef
