**[Hailo-8 / DFC 3.33.1] 8 cases where the HEF compiles cleanly and passes SDK_BIT_EXACT, but the chip output is wrong (repros + workarounds)**
Several common layers compile with no warning and look correct in the emulator, but give wrong results on the Hailo-8. Each case below has a minimal PyTorch repro, measured numbers, the DFC rule we traced it to, and a workaround.
Environment
  • Hailo-8 PCIe (two devices, both reproduce everything), Dataflow Compiler 3.33.1, HailoRT 4.23.0 with its bundled firmware, Linux x86-64.
  • PyTorch 2.4 export to ONNX opset 17.
  • Default flow: optimization_level=0, compression_level=0, 64 N(0,1) calibration frames, no other model-script lines unless stated.
Method
check.py (at the end of this post) builds the ONNX with that flow. It then runs the same 8 raw quantized frames on the chip, in SDK_BIT_EXACT and in onnxruntime. It reports:
  • the percentage of output elements where the chip differs from the emulator;
  • SNR vs float for both;
  • whether batch output equals frame-by-frame output.
The chip is deterministic: identical across runs, reboots and both devices, except where noted. All numbers were measured on 2026-10-26 with exactly the steps below.
# Case Chip ≠ emulator SNR vs float, chip / emulator Workaround
1 ConvTranspose with kernel = stride (2/2, 4/4) 99.5% −9.6 / 35.1 dB force SUPER_DECONV
2 GroupNorm(1, C) 49.3% 3.1 / 36.0 dB rewrite with plain ops
3 Dilated conv on a 9–11-px-wide piece ~99% of that piece; changes with earlier frames −2.6 / 37.9 dB pad W to a multiple of 8, then crop
4 INPUT_FEATURES split of a dynamic matmul (attention P·V) 98.3% 5.3 / 37.3 dB pin the matmul’s subclusters
5 Matmul whose second operand comes from a ReLU 88.1% 9.6 / 27.0 dB force_range_out on the producer
6 Softmax denominator wraps off-calibration chip = emulator, both wrong −16.3 / −16.3 dB wider denominator range
7 Emulator clamps UINT16 inputs at 32767 emulator wrong, chip right — —
8 ConvTranspose k3 s2 p1 parses to 48×48, not 47×47 wrong shape — k4 s2 p1 or crop
1. ConvTranspose with kernel = stride is wrong on the chip
ConvTranspose2d(C, C, 2, stride=2) and (4, stride=4) are 99.5% wrong on the chip, while the emulator is correct.
ConvTranspose DFC route (auto.alls) Chip ≠ emulator SNR chip / emulator
k2 s2, C16 24×24 defuse(deconv1, 1, defuse_type=DECONV) 99.50% (max 212 LSB) −9.6 / 35.1 dB
k2 s2, C64 16×16 DECONV 99.54% −10.5 / 34.8 dB
k4 s4, C16 24×24 DECONV 99.48% −6.2 / 38.2 dB
k4 s4, C64 12×12 DECONV 99.48% −9.1 / 36.2 dB
k4 s2 p1 DECONV 0% 36.3 / 36.3 dB
k8 s4 p2 DECONV 0% 38.6 / 38.6 dB
k16 s8 p4 DECONV 0% 41.4 / 41.4 dB
k2 s2 with SUPER_DECONV forced, same HAR SUPER_DECONV 0% 35.1 / 35.1 dB
Route. hailo_sdk_common/numeric_utils/numeric_utils.py::is_super_deconv() sends exactly five kernel/stride pairs to the native DECONV (feature-interleave) path and everything else to SUPER_DECONV:
return not ((k == 4 and s == 2) or (k == 4 and s == 4) or (k == 2 and s == 2)
            or (k == 8 and s == 4) or (k == 16 and s == 8))
  • kernel = 2 × stride (k4s2, k8s4, k16s8): bit-exact.
  • kernel = stride (k2s2, k4s4), the standard non-overlapping upsamplers: wrong, deterministically. The output is not a permutation of the correct one.
Steps
import torch, torch.nn as nn
class M(nn.Module):
    def __init__(s):
        super().__init__(); s.up = nn.ConvTranspose2d(16, 16, 2, 2); s.out = nn.Conv2d(16, 16, 1)
    def forward(s, x): return s.out(s.up(x))
torch.manual_seed(0)
torch.onnx.export(M().eval(), torch.randn(1, 16, 24, 24), "m.onnx", input_names=["x"], opset_version=17, dynamo=False)
python check.py m.onnx prints:
chip != emulator: 99.50% of outputs, max 212 LSB
SNR vs float: chip -9.6 dB, emulator 35.1 dB
Put the line below in super.alls and run python check.py m.onnx super.alls. The result is chip != emulator: 0.00%, 35.1 / 35.1 dB.
deconv1_defuse_conv, deconv1_defuse_d2s = defuse(deconv1, 1, defuse_type=SUPER_DECONV)
Workaround. The SUPER_DECONV line above, or in ONNX a 1×1 conv (C → 4C) followed by DepthToSpace(2, CRD). Both are bit-exact on the chip.
2. GroupNorm(1, C) is wrong on the chip
nn.GroupNorm(1, C) gives 49% wrong outputs on the chip. GroupNorm with 2, 4 or 8 groups is exact.
Model (C = 64, 20×20) Statistics tensor in the DFC’s decomposition Chip ≠ emulator SNR chip / emulator
GroupNorm(1, 64) 1 channel, 16-bit 49.27% (max 108 LSB) 3.1 / 36.0 dB
GroupNorm(2, 64) 2 channels 0% 35.6 / 35.6 dB
GroupNorm(4, 64) 4 channels 0% 35.5 / 35.5 dB
GroupNorm(8, 64) 8 channels 0% 35.2 / 35.2 dB
channel-only LayerNorm(C) (ConvNeXt style) 1 channel, no spatial reduce 0.01% (1 LSB) 36.5 / 36.5 dB
same maths rewritten (below) 1 channel, 8-bit, AVGPOOL 0% 35.9 / 35.9 dB
A 35-shape grid (C 8–128 × H = W 8–40) is wrong at every shape: 37–52% of outputs, by up to 131 LSB. With two contexts, a frame’s output also depends on the previous frame.
Route. decompose_norm_layer_algo_v2 builds the same layer graph for GroupNorm(1) and GroupNorm(4):
channel reduce_mean → spatial reduce_mean → resize → ew_sub → square → conv_var_inv → spatial reduce_mean → resize → ew_mult, all a16_w16.
The only difference is the width of the statistics tensor: 1 channel vs 4. The failing piece is the 16-bit spatial reduce_mean/resize of a 1-channel map:
  • 2, 4 or 8 channels are exact.
  • A 1-channel map without the spatial step (channel LayerNorm) is exact.
No layer_norm_decomposition option fixes it:
  • equalization, nudging, optimize_ew_mult and square_12_bit: still 49% wrong;
  • split_precision: 31% wrong;
  • a8_w8: does not compile;
  • ppu: not supported on Hailo-8.
Steps
class M(nn.Module):
    def __init__(s):
        super().__init__(); s.gn = nn.GroupNorm(1, 64); s.out = nn.Conv2d(64, 64, 1)
        with torch.no_grad(): s.gn.weight.uniform_(0.5, 1.5); s.gn.bias.normal_(0, 0.1)
    def forward(s, x): return s.out(s.gn(x))
torch.onnx.export(M().eval(), torch.randn(1, 64, 20, 20), "m.onnx", input_names=["x"], opset_version=17, dynamo=False)
python check.py m.onnx prints chip != emulator: 49.32% ... SNR vs float: chip 3.1 dB, emulator 36.0 dB. With GroupNorm(4, 64) the result is 0.00%.
Workaround. The same function with plain ops; the chip then equals the emulator:
m = x.mean((2, 3), keepdim=True).mean(1, keepdim=True)
d = x - m
v = (d * d).mean((2, 3), keepdim=True).mean(1, keepdim=True)
y = d * torch.reciprocal(torch.sqrt(v + eps)) * weight.view(1, -1, 1, 1) + bias.view(1, -1, 1, 1)
3. Dilated conv is wrong on 9–11-pixel-wide pieces, and depends on earlier frames
When the compiler gives a dilated 3×3 conv a row piece between 9 and 8 + dilation − 1 pixels wide, that piece is ~99% wrong on the chip. Its values also change with what ran before.
Conv2d(24, 24, 3, padding=d, dilation=d), H = 30.
Layer compiled as one piece:
W d = 2 d = 3 d = 4 d = 6
8 exact
9 98.7% wrong, −1.8 dB 98.7% wrong, −2.3 dB 98.8% wrong, −2.7 dB
10 exact 98.7% wrong, −2.6 dB 98.9% wrong, −2.8 dB
11 (split) 98.8% wrong, −3.0 dB
13 exact
Layer split by the compiler (defuse_type=SPATIAL):
W d = 2 d = 3 d = 4
11–13 exact (2 slices) exact (W = 12)
17 52.2% wrong (one 9-wide slice)
18 exact (3 slices) 54.9% wrong (2 slices of 9) 54.8% wrong (2 slices of 9)
50 exact (7 slices) 19.7% wrong: slices 16+16+8+10, only columns 40–49 wrong 19.7% wrong
50, padded to 56 then cropped 0%, 37.9 dB
Rule (d = 2–4, every case measured). A piece is wrong exactly when its width is 9 … 8 + d − 1, that is, just past an 8-column boundary by less than the dilation. At d = 6, width 13 is exact; widths 9–12 at d = 6 are untested.
  • The emulator gives 37–38 dB in every case.
  • In every wrong case, the chip’s batch output ≠ its frame-by-frame output, and the first run after loading the HEF differs from later runs. That looks like the piece reading stale memory, probably right-edge padding that is never written.
  • Changing layer_output_buffers_format or the defuse count does not help. Compiler string: “columns dilation > 2 is not supported for convmxns1_no_contexts”.
Steps
m = nn.Conv2d(24, 24, 3, padding=3, dilation=3).eval()
torch.onnx.export(m, torch.randn(1, 24, 30, 50), "m.onnx", input_names=["x"], opset_version=17, dynamo=False)
chip != emulator: 19.73% of outputs, max 149 LSB
SNR vs float: chip 4.8 dB, emulator 37.9 dB
chip batch == chip frame-by-frame: False
At W = 9 the whole output is ~99% wrong.
Workaround. Zero-pad W to a multiple of 8, run the conv, then crop. This is the same function, and it is exact on the chip:
y = conv(F.pad(x, (0, 56 - 50)))[..., :50]   # export with static pads
4. INPUT_FEATURES split of a dynamic matmul is wrong on the chip (attention softmax×V)
In plain attention the compiler splits softmax(QKᵀ)·V with INPUT_FEATURES. That split is 98% wrong on the chip; keeping the matmul whole is bit-exact.
Attention (C = 32) Default compile, defuse(matmul2, 2, defuse_type=INPUT_FEATURES) P·V pinned to 8 subclusters
64 tokens, t = 0.05 98.68% wrong, 5.5 / 39.9 dB 0%, 39.9 / 39.9 dB
784 tokens, t = 0.2 98.34% wrong, 5.3 / 37.3 dB, batch ≠ frame-by-frame 0%, 37.3 / 37.3 dB
256 tokens, K bias +3 98.19% wrong, 5.4 / 22.0 dB 0%, 22.0 / 22.0 dB
  • Q·Kᵀ and the softmax alone are bit-exact on the chip; only P·V is wrong. The error is not a permutation and does not correlate with any operand.
  • It is not specific to softmax. On the Qᵀ·K probe of case 5, with case 5’s fix applied (4.3% baseline), forcing matmul1_fs_0, matmul1_fs_1, matmul1_d0, matmul1_d1, matmul1_dc = defuse(matmul1, 2, defuse_type=INPUT_FEATURES) gives 96.1% wrong (3.8 dB), while the emulator gives 33.4 dB.
  • The compiler rejects this split for the attention Q·K (“Defuse features split 2 with unsupported alignment”), but accepts it for P·V.
  • At more than ~400 tokens, the same split also causes _Map_base::at when the compiler’s own auto.alls is loaded back.
Steps
class Attn(nn.Module):
    def __init__(s, c=32, t=0.2):
        super().__init__(); s.q, s.k, s.v, s.out = (nn.Conv2d(c, c, 1) for _ in range(4)); s.t = t
    def forward(s, x):
        b, c, h, w = x.shape
        q = s.q(x).reshape(b, c, h * w).transpose(1, 2)
        k = s.k(x).reshape(b, c, h * w)
        v = s.v(x).reshape(b, c, h * w).transpose(1, 2)
        p = torch.softmax((q @ k) * s.t, dim=-1)
        return s.out((p @ v).transpose(1, 2).reshape(b, c, h, w))
torch.onnx.export(Attn().eval(), torch.randn(1, 32, 28, 28), "m.onnx", input_names=["x"], opset_version=17, dynamo=False)
python check.py m.onnx prints chip != emulator: 98.34% ... chip 5.3 dB, emulator 37.3 dB. With the line below in pin.alls, python check.py m.onnx pin.alls gives 0.00%, 37.3 / 37.3 dB.
compilation_param(matmul2, resources_allocation_strategy=manual_scs_selection, number_of_subclusters=8)
Workaround. Pin every softmax×V matmul as above (2 or 8 subclusters both work).
5. Matmul with a ReLU second operand: the chip reads values above 127 as negative
When K in Q·Kᵀ comes from a ReLU, the chip output is 88% wrong. The chip writes K unsigned (0..255), and the matmul reads it as int8.
Probe: x → conv3×3 → ReLU → {conv1×1 → ReLU = Q, conv1×1 → ReLU = K} → Qᵀ·K → conv1×1, C = 32, 10×10.
Input amplitude Default With force_range_out=[0, 2·max] on K
1.0 (= calibration) 88.06% wrong, 9.6 / 27.0 dB 4.33%, 26.7 / 33.4 dB
2.0 98.74%, 1.3 / 8.9 dB 87.0%, 6.1 / 7.8 dB
Mechanism (modelled bit-exactly, 10,000 of 10,000 outputs):
  • base_hailo_layer.get_signed_output() marks any 8-bit producer of a matmul’s weights input as signed, so the emulator saturates K at 127.
  • On the chip, that producer’s activation and output stage runs unsigned (0..255) when its function is non-negative.
  • The matmul then reads the byte as int8, so K values above 127 wrap negative.
Linear (non-ReLU) K and V are exact.
Steps
import torch, torch.nn as nn, torch.nn.functional as F
class M(nn.Module):
    def __init__(s, c=32, h=10):
        super().__init__(); s.stem = nn.Conv2d(c, c, 3, 1, 1); s.q = nn.Conv2d(c, c, 1); s.k = nn.Conv2d(c, c, 1)
        s.out = nn.Conv2d(h * h, c, 1)
    def forward(s, x):
        y = F.relu(s.stem(x)); b, c, h, w = y.shape
        q = F.relu(s.q(y)).reshape(b, c, h * w).transpose(1, 2)
        k = F.relu(s.k(y)).reshape(b, c, h * w)
        return s.out((q @ k).transpose(1, 2).reshape(b, h * w, h, w))
torch.onnx.export(M().eval(), torch.randn(1, 32, 10, 10), "m.onnx", input_names=["x"], opset_version=17, dynamo=False)
python check.py m.onnx prints 88.06% ... chip 9.6 dB, emulator 27.0 dB. The K producer here is conv2, with calibrated max 1.2565. With the line below in fix.alls, the chip gives 26.7 dB.
quantization_param(conv2, force_range_out=[0, 2.51307])
6. Softmax denominator accumulator wraps when inputs leave the calibration range
The quantizer gives the softmax denominator a 16-bit wrapping accumulator sized from calibration. Rows whose Σexp exceed it get a reciprocal of ≈0. Chip and emulator agree, so no DFC report shows it.
hailo_model_optimization/acceleras/hailo_layers/hailo_reduce_sum.py:
max_final_accumulator_by_channel = np.maximum(np.abs(pre_act_stats.min), np.abs(pre_act_stats.max))  # calibration
utilize_wraparound = self.act_op.is_negative_input()      # True for the softmax denominator (-sum exp)
if utilize_wraparound:  # fixes an edge case where resulted accumulator is exactly -2**15
force_range_preact does not change the accumulator.
Measured on the case-4 model, 784 tokens, P·V pinned. Chip = emulator in every row:
Temperature Calibrated / worst-case denominator Amplitude 0.25 / 0.5 / 1.0, default Same, sized N × max(exp)
t = 0.2 542.7 / 784 9.2 / 17.5 / 37.3 dB 31.0 / 36.0 / 37.0 dB
t = 1.0 144.8 / 784 −14.6 / −16.3 / 17.8 dB 4.4 / 9.2 / 13.8 dB
From a 451,584-row map on a production model:
  • row sums 32,771–40,000 get a reciprocal of 0–2 instead of 2;
  • row sums 40,000–65,535 get 0 instead of 1–2.
In production YOLO26m (C2PSA, 784 tokens), 2.6% of attention rows on real images are above 32,770.
Steps. Export the case-4 model with t=1.0, then run python check.py m.onnx pin.alls 0.5. It prints chip -16.3 dB, emulator -16.3 dB; at amplitude 1.0 the result is 17.8 dB.
Fix used. Run this before optimize(); at amplitude 0.5 it gives 9.2 dB:
from hailo_model_optimization.acceleras.hailo_layers.hailo_reduce_sum import HailoReduceSum
orig = HailoReduceSum.create_hw_params
def patched(self, wc, target, hw_shifts=None):
    if "reduce_sum_softmax" in self.full_name:
        st = self.act_op.get_input_stats(0)
        worst = self.reduce_sum_op._reduce_size * float(np.max(np.abs(self.reduce_sum_op.get_input_limvals(0)))) \
                * float(np.max(np.abs(np.asarray(self.reduce_sum_op.kernel))))
        new = st._replace(min=np.minimum(st.min, -worst))
        self.act_op.get_input_stats = lambda i, _s=new, _g=self.act_op.get_input_stats: _s if i == 0 else _g(i)
    try: return orig(self, wc, target, hw_shifts=hw_shifts)
    finally: self.act_op.__dict__.pop("get_input_stats", None)
HailoReduceSum.create_hw_params = patched
It costs up to 4 dB in distribution (t = 1.0: 17.8 → 13.8 dB), because the 8-segment reciprocal table is spread over a wider range. A saturating accumulator would avoid the trade-off.
7. SDK_BIT_EXACT clamps UINT16 inputs at 32767; the chip uses 0..65535
For a 16-bit-input network, the emulator behaves as if raw inputs were clamped to 32767. The chip uses the full range.
Probe: conv1×1 → y + y + y → conv1×1, C = 16, 24×24, every layer a16_w16, input zero point 16,006. The frame is the zero point everywhere except one element.
Raw input element Chip output Emulator output Output elements that differ
30,000 / 32,000 / 32,767 25,066 / 26,012 / 26,375 same 0
33,000 26,485 26,375 16
35,000 27,432 26,375 16
40,000 29,798 26,375 16
50,000 / 65,535 32,767 26,375 16
Steps
class M(nn.Module):
    def __init__(s, c=16):
        super().__init__(); s.a = nn.Conv2d(c, c, 1); s.b = nn.Conv2d(c, c, 1)
    def forward(s, x): y = s.a(x); return s.b(y + y + y)
  1. Put this line in a16.alls:
quantization_param([input_layer1, conv1, mul_and_add1, ew_add1, conv2, output_layer1], precision_mode=a16_w16)
  1. Run python check.py m.onnx a16.alls.
  2. Feed frames that are qp_zp everywhere except X[k, 12, 12, 0] = v to the chip and to SDK_BIT_EXACT, and compare element [12, 12, 0].
Also, FormatType.AUTO rejects uint16 arrays for this input (“numpy array item size is 2, not 1”). Pass FormatType.UINT16 explicitly.
8. ConvTranspose k3 s2 p1 parses to 48×48 where ONNX gives 47×47
With no output_padding, ConvTranspose2d(16, 16, 3, 2, 1) on a 24×24 input is 47×47 in ONNX: (24 − 1)·2 − 2 + 3 = 47. The DFC parses it to 48×48 without a warning.
import torch, torch.nn as nn, numpy as np
m = nn.Sequential(nn.ConvTranspose2d(16, 16, 3, 2, 1), nn.Conv2d(16, 16, 1)).eval()
torch.onnx.export(m, torch.randn(1, 16, 24, 24), "m.onnx", input_names=["x"], opset_version=17, dynamo=False)
r = ClientRunner(hw_arch="hailo8"); r.translate_onnx_model("m.onnx", "probe")
with r.infer_context(InferenceContext.SDK_NATIVE) as c:
    print(np.asarray(r.infer(c, np.zeros((1, 24, 24, 16), np.float32))).shape)   # (1, 48, 48, 16)
This is related to the existing output_padding thread, but no output_padding is involved here.
What would help
  1. Confirmation of cases 1–5, and whether they are fixed in a newer DFC or firmware.
  2. For cases 1 and 2: is the cause the generated program or the hardware unit? We cannot tell from outside.
  3. A saturating softmax-denominator option (case 6), and emulator fixes for case 7, so that SDK_BIT_EXACT can be trusted as a pre-silicon check.
  4. Compile-time errors instead of silently wrong HEFs for cases 1, 3 and 4, and a parse error for case 8.
Happy to share the ONNX files, HARs and HEFs.
check.py
# usage: python check.py m.onnx [extra.alls] [amplitude]
import os, sys
import numpy as np, onnx, onnxruntime as ort
from hailo_platform import (HEF, VDevice, ConfigureParams, HailoStreamInterface, InferVStreams,
                            InputVStreamParams, OutputVStreamParams, FormatType)
onnx_path = sys.argv[1]
extra = open(sys.argv[2]).read() if len(sys.argv) > 2 and sys.argv[2] != "-" else ""
amp = float(sys.argv[3]) if len(sys.argv) > 3 else 1.0
_, c, h, w = [d.dim_value for d in onnx.load(onnx_path).graph.input[0].type.tensor_type.shape.dim]
# parse, quantize (level 0, 64 N(0,1) calibration frames), compile
runner = ClientRunner(hw_arch="hailo8")
runner.translate_onnx_model(onnx_path, "probe")
runner.load_model_script("model_optimization_flavor(optimization_level=0, compression_level=0)\n" + extra)
runner.optimize(np.random.default_rng(1).normal(0, 1, (64, h, w, c)).astype(np.float32))
runner.save_har("q.har")
open("m.hef", "wb").write(runner.compile())
# 8 test frames N(0, amp) quantized to the HEF's raw input format
hef = HEF("m.hef")
ii, oi = hef.get_input_vstream_infos()[0], hef.get_output_vstream_infos()[0]
u16 = "16" in str(ii.format.type)
X = np.random.default_rng(0).normal(0, amp, (8, h, w, c)) / ii.quant_info.qp_scale + ii.quant_info.qp_zp
X = np.clip(np.round(X), 0, 65535 if u16 else 255).astype(np.uint16 if u16 else np.uint8)
xf = (X.astype(np.float32) - ii.quant_info.qp_zp) * ii.quant_info.qp_scale
# float reference and SDK_BIT_EXACT on the same dequantized frames
sess = ort.InferenceSession(onnx_path, providers=["CPUExecutionProvider"])
ref = np.concatenate([sess.run(None, {sess.get_inputs()[0].name: f[None].transpose(0, 3, 1, 2)})[0]
                      for f in xf]).transpose(0, 2, 3, 1)
q = ClientRunner(har="q.har")
with q.infer_context(InferenceContext.SDK_BIT_EXACT) as ctx:
    emu = np.asarray(q.infer(ctx, xf)).reshape(ref.shape)
# chip: whole batch, then frame by frame
p = VDevice.create_params()
if os.environ.get("HAILO_DEVICE_ID"):
    p.device_ids = [os.environ["HAILO_DEVICE_ID"]]
vd = VDevice(p)
try:
    ng = vd.configure(hef, ConfigureParams.create_from_hef(hef, interface=HailoStreamInterface.PCIe))[0]
    ip = InputVStreamParams.make(ng, format_type=FormatType.UINT16 if u16 else FormatType.UINT8)
    op = OutputVStreamParams.make(ng, format_type=FormatType.AUTO)
    with ng.activate(ng.create_params()), InferVStreams(ng, ip, op) as pipe:
        run = lambda x: np.asarray(pipe.infer({ii.name: x})[oi.name]).copy()
        chip = run(X).reshape(ref.shape).astype(np.int64)
        chip1 = np.concatenate([run(X[i:i + 1]) for i in range(len(X))]).reshape(ref.shape).astype(np.int64)
finally:
    vd.release()
qo = oi.quant_info
hi = 65535 if "16" in str(oi.format.type) else 255
emu_q = np.clip(np.round(emu / qo.qp_scale + qo.qp_zp), 0, hi).astype(np.int64)
deq = lambda a: (a - qo.qp_zp) * qo.qp_scale
snr = lambda a: 10 * np.log10((ref ** 2).mean() / ((deq(a) - ref) ** 2).mean())
d = np.abs(chip - emu_q)
print(f"chip != emulator: {100 * (d > 0).mean():.2f}% of outputs, max {d.max()} LSB")
print(f"SNR vs float: chip {snr(chip):.1f} dB, emulator {snr(emu_q):.1f} dB")
print(f"chip batch == chip frame-by-frame: {(chip == chip1).all()}")
