HAILO-15H custom board flashing
We made a custom board with HAILO-15H. I would like to ask if the flashing process is the same as the SBC kit?
We cannot communicate with HAILO trough UART in the first place, so just to be sure about the flashing process.
Thank you.
Yes, the first steps will be as described in the SBC Quick Start Guide. However you will need to create your own Yocto build. The prebuilt images provided by Hailo will not run on your board as it contains Hailo-15 production devices. Hailo-15 support secure boot and requires the images to be signed with your private key and a certificate from Hailo. The process is described in the Hailo OS Secure Boot User Guide.
