I am attempting to run inference using the pyHailoRT API with a Hailo-10H PCIe device on Windows 11. The device is detected correctly with hailortcli scan, but when I call VDevice.configure() in Python to load a .hef file, it fails with:
hailo_platform.pyhailort.pyhailort.HailoRTException: libhailort failed with error: 7 (HAILO_NOT_IMPLEMENTED)
Environment:
OS: Windows 11 Pro 64-bit
Device: Hailo-10H (PCIe, address 0000:02:00.0)
HailoRT version: [insert exact version shown in
hailortcli --version] -
pyHailoRT installed from:
C:\Program Files\HailoRT\pythonwheel -
Python version: 3.11
Model:
yolov11l.hef(from Model Zoo)
Steps to Reproduce:
Installed HailoRT MSI (checked pyHailoRT option).
Confirmed the card appears in
hailortcli scan. -
Ran a Python script that creates a
VDeviceand configures the HEF via:configure_params = ConfigureParams.create_from_hef(hef=hef, interface=HailoStreamInterface.PCIe) network_groups = target.configure(hef, configure_params) -
The above call fails with error code 7 (
HAILO_NOT_IMPLEMENTED).
Expected Behavior:
The HEF should be configured successfully, allowing inference through PCIe on Windows.
Actual Behavior:
The device is detected but configuration fails with HAILO_NOT_IMPLEMENTED.
Questions:
Is PCIe inference with pyHailoRT currently supported on Windows for Hailo-10H?
If not, is there a planned release adding PCIe support, or is Linux required for hardware inference?
Can simulation mode be used to validate the pipeline on Windows until full PCIe support is available?
Thank you for your assistance.
