Hailo 10H not working with OpenWrt
Hi everyone,
I’m working with a Hailo-10H on an OpenWRT system, and I’m encountering a “.HEF corrupted” error whenever I run inference (including commands like run2). I’ve already verified the HEF using hash checks, HEF parse, and confirmed my HailoRT and Zoo versions. The same HEF works correctly on my x86 Linux machine, and my Hailo-8L runs fine on the same OpenWRT setup.
Has anyone seen this behavior or knows what might cause it? I’ve attached logs for reference. Any insights would be greatly appreciated.
Thanks!
LOG :
Hailo 8 in Banana PI
root@OpenWrt:~# hailortcli fw-control identify
[ 532.303460] mtk-pcie-gen3 11280000.pcie: msi#0x1 address_hi 0x0 address_lo 0x11280c00 data 1
Executing on device: 0003:01:00.0
Identifying board
Control Protocol Version: 2
Firmware Version: 4.23.0 (release,app,extended context switch buffer)
Logger Version: 0
Board Name: Hailo-8
Device Architecture: HAILO8L
Serial Number: HLDDLBB244701012
Part Number: HM21LB1C2LAE
root@OpenWrt:~# hailortcli run /tmp/yolov5m_seg_8L.hef
Running streaming inference (/tmp/yolov5m_seg_8L.hef):
Transform data: true
Type: auto
Quantized: true
[ 843.613454] mtk-pcie-gen3 11280000.pcie: msi#0x1 address_hi 0x0 address_lo 0x11280c00 data 1
Network yolov5m_seg/yolov5m_seg: 20% | 27 | FPS: 26.98 | ETA: 00:00:04
Network yolov5m_seg/yolov5m_seg: 40% | 55 | FPS: 27.47 | ETA: 00:00:03
Network yolov5m_seg/yolov5m_seg: 60% | 83 | FPS: 27.64 | ETA: 00:00:02
Network yolov5m_seg/yolov5m_seg: 80% | 110 | FPS: 27.47 | ETA: 00:00:01
Network yolov5m_seg/yolov5m_seg: 100% | 138 | FPS: 27.57 | ETA: 00:00:00
Network yolov5m_seg/yolov5m_seg: 100% | 138 | FPS: 27.37 | ETA: 00:00:00
Inference result:
Network group: yolov5m_seg
Frames count: 138
FPS: 27.37
Send Rate: 269.09 Mbit/s
Recv Rate: 1474.40 Mbit/s
root@OpenWrt:~# cat /tmp/sysinfo/board_name
bananapi,bpi-r4
root@OpenWrt:~# dmesg | grep hailo
[ 13.279187] hailo: Init module. driver version 4.23.0
[ 13.284358] hailo 0003:01:00.0: assign IRQ: got 115
[ 13.289233] hailo 0003:01:00.0: Probing on: 1e60:2864…
root@OpenWrt:~# hailortcli run2 set-net /tmp/yolov5m_seg_8L.hef
[HailoRT CLI] [warning] “hailortcli run2” is not optimized for single model usage. It is recommended to use “hailortcli run” command for a single m[ 1115.138790] mtk-pcie-gen3 11280000.pcie1
odel
[> ] 0% 00:00:05
yolov5m_seg: fps: 0.00
[===> ] 20% 00:00:04
yolov5m_seg: fps: 26.96
[=======> ] 40% 00:00:03
yolov5m_seg: fps: 27.47
[===========> ] 60% 00:00:02
yolov5m_seg: fps: 27.63
[===============> ] 80% 00:00:01
[===================>] 100% 00:00:00
yolov5m_seg: fps: 27.57
root@OpenWrt:~#
Hailo 10 in Banana Pi
root@OpenWrt:~# hailortcli --version
HailoRT-CLI version 5.1.1
[ 201.691732] mtk-pcie-gen3 11290000.pcie: msi#0x1 address_hi 0x0 address_lo 0x11290c00 data 1
Executing on device: 0002:01:00.0
Identifying board
Firmware Version: 5.1.1 (release,app)
Logger Version: 0
Device Architecture: HAILO10H
root@OpenWrt:~# hailortcli run2 set-net /tmp/yolov3_10H_RGB.hef
[ 331.099129] mtk-pcie-gen3 11290000.pcie: msi#0x1 address_hi 0x0 address_lo 0x11290c00 data 1
[HailoRT] [error] CHECK_SUCCESS failed with status=HAILO_HEF_FILE_CORRUPTED(91)
[HailoRT CLI] [error] CHECK_SUCCESS failed with status=HAILO_HEF_FILE_CORRUPTED(91)
[HailoRT] [error] Failed to send request, status = HAILO_COMMUNICATION_CLOSED(62)
[HailoRT] [critical] Failed to destroy VDevice! status = HAILO_COMMUNICATION_CLOSED(62)
[HailoRT] [critical] Failed to destroy Device! status = HAILO_COMMUNICATION_CLOSED(62)
bananapi,bpi-r4
root@OpenWrt:~# hailortcli run /tmp/yolov3_10H_RGB.hef
Running streaming inference (/tmp/yolov3_10H_RGB.hef):
Type: auto
Quantized: true
[ 372.379934] mtk-pcie-gen3 11290000.pcie: msi#0x1 address_hi 0x0 address_lo 0x11290c00 data 1
[HailoRT CLI] [error] CHECK failed - The “run” command is not supported for this device type! Use “run2” instead.
[ 13.944561] hailo1x: Init module. driver version 5.1.1
[ 13.949797] hailo1x 0002:01:00.0: assign IRQ: got 118
[ 13.954861] hailo1x 0002:01:00.0: Probing on: 1e60:45c4…
Hey @Aravind_R,
The H8L setup appears to be functioning properly, so we can rule out a PCIe issue.
Regarding the run command for H10: this operation is not supported.
The model appears to be corrupted. This could stem from several issues, but let’s start with a basic sanity check. Could you please:
  1. Select any model from the model zoo and run it using run2 to verify that the setup itself is functioning correctly. If that works, it will confirm the HEF file is corrupted.
  2. Run hailortcli parse-hef on the corrupted model to help diagnose the issue.
Hi @omria ,
I have tried both. I used run2 command → HEF corruption output.I have used Hef parse to verify the model. Model is built for Hailo 10H( I have also tested the same models by connecting the Hailo 10 H to a Linux PC and verified the model is fine - Same HailoRT version also ). I have done Hash test to verify its not a broken file.
10H module → in X86 PC → Same Models → Works fine
8L Module → OpenWrt → Same PCIe→ Works fine
10 H Module → OpenWrt → Same PCIe → Hash Error → HEF corrupted
Same HailoRT version while verifying Models with X86 PC
Are all the models running on OpenWrt with the H10 producing this corruption error? If so, could you please share the hailort.log file? That should show me the exact error that occurred during the run. And if it’s just this specific model, could you send it to me so I can take a look?
@omria
All the models running on Hailo 10 is giving this same error. tried it with multiple models(Verified the same models in X86 connecting hailo 10 to it ) its the Embedded system that is not working with Hailo 10( while it is working fine with 8L)
LOG FILE:
root@OpenWrt:~# hailortcli logs runtime
Mar 9 12:34:56 hailo10 syslog.info syslogd started: BusyBox v1.35.0
Mar 9 12:34:56 hailo10 kern.notice kernel: klogd started: BusyBox v1.35.0 ()
Mar 9 12:34:56 hailo10 kern.info kernel: Booting Linux on physical CPU 0x0000000000 [0x410fd034]
Mar 9 12:34:56 hailo10 kern.notice kernel: Linux version 5.15.325.15.32-yocto-standard-01576-g55eda3b378bf (oe-user@oe-host) (aarch64-poky-linux-gcc (GCC) 11.5.0, GNU ld (GNU Binutils) 2.38.20220708) #1 SMP PREEMPT Wed Oct 29 18:22:56 UTC 2025
Mar 9 12:34:56 hailo10 kern.info kernel: Machine model: Hailo - Hailo10-M.2 2280 ES 4GiB 10 layers (board-sku-1)
Mar 9 12:34:56 hailo10 kern.info kernel: Reserved memory: created DMA memory pool at 0x0000000151200000, size 750 MiB
Mar 9 12:34:56 hailo10 kern.info kernel: OF: reserved mem: initialized node integrated_nnc_dma_cma,cma, compatible id shared-dma-pool
Mar 9 12:34:56 hailo10 kern.info kernel: Reserved memory: created CMA memory pool at 0x00000000b0000000, size 32 MiB
Mar 9 12:34:56 hailo10 kern.info kernel: OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
Mar 9 12:34:56 hailo10 kern.info kernel: Zone ranges:
Mar 9 12:34:56 hailo10 kern.info kernel: Normal [mem 0x0000000080000000-0x000000017fffffff]
Mar 9 12:34:56 hailo10 kern.info kernel: Movable zone start for each node
Mar 9 12:34:56 hailo10 kern.info kernel: Early memory node ranges
Mar 9 12:34:56 hailo10 kern.info kernel: node 0: [mem 0x0000000080000000-0x00000000801fffff]
Mar 9 12:34:56 hailo10 kern.info kernel: node 0: [mem 0x0000000080200000-0x00000000802effff]
Mar 9 12:34:56 hailo10 kern.info kernel: node 0: [mem 0x00000000802f0000-0x000000008dffffff]
Mar 9 12:34:56 hailo10 kern.info kernel: node 0: [mem 0x000000008e000000-0x000000009fffffff]
Mar 9 12:34:56 hailo10 kern.info kernel: node 0: [mem 0x00000000a0000000-0x00000001511fffff]
Mar 9 12:34:56 hailo10 kern.info kernel: node 0: [mem 0x0000000151200000-0x000000017fffffff]
Mar 9 12:34:56 hailo10 kern.info kernel: Initmem setup node 0 [mem 0x0000000080000000-0x000000017fffffff]
Mar 9 12:34:56 hailo10 kern.info kernel: psci: probing for conduit method from DT.
Mar 9 12:34:56 hailo10 kern.info kernel: psci: PSCIv1.1 detected in firmware.
Mar 9 12:34:56 hailo10 kern.info kernel: psci: Using standard PSCI v0.2 function IDs
Mar 9 12:34:56 hailo10 kern.info kernel: psci: MIGRATE_INFO_TYPE not supported.
Mar 9 12:34:56 hailo10 kern.info kernel: psci: SMC Calling Convention v1.4
Mar 9 12:34:56 hailo10 kern.info kernel: percpu: Embedded 18 pages/cpu s33752 r8192 d31784 u73728
Mar 9 12:34:56 hailo10 kern.debug kernel: pcpu-alloc: s33752 r8192 d31784 u73728 alloc=18*4096
Mar 9 12:34:56 hailo10 kern.debug kernel: pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
Mar 9 12:34:56 hailo10 kern.info kernel: Detected VIPT I-cache on CPU0
Mar 9 12:34:56 hailo10 kern.info kernel: CPU features: detected: GIC system register CPU interface
Mar 9 12:34:56 hailo10 kern.info kernel: CPU features: detected: ARM erratum 845719
Mar 9 12:34:56 hailo10 kern.info kernel: Built 1 zonelists, mobility grouping on. Total pages: 1032192
Mar 9 12:34:56 hailo10 kern.notice kernel: Kernel command line: quiet loglevel=3 rootwait phram.phram=ramdisk0,0x90000000,0x10000000,1 root=/dev/dm-0 dm-mod.create="dm-verity,ro,0 134408 verity 1 /dev/mtdblock0 /dev/mtdblock0 4096 4096 16801 16802 sha256 8862004e61262
Mar 9 12:34:56 hailo10 kern.info kernel: Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
Mar 9 12:34:56 hailo10 kern.info kernel: Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
Mar 9 12:34:56 hailo10 kern.info kernel: mem auto-init: stack:off, heap alloc:off, heap free:off
Mar 9 12:34:56 hailo10 kern.info kernel: Memory: 3003776K/4194304K available (6528K kernel code, 816K rwdata, 2144K rodata, 1024K init, 626K bss, 1157760K reserved, 32768K cma-reserved)
Mar 9 12:34:56 hailo10 kern.info kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Mar 9 12:34:56 hailo10 kern.info kernel: rcu: Preemptible hierarchical RCU implementation.
Mar 9 12:34:56 hailo10 kern.info kernel: rcu: RCU event tracing is enabled.
Mar 9 12:34:56 hailo10 kern.info kernel: rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
Mar 9 12:34:56 hailo10 kern.info kernel: Trampoline variant of Tasks RCU enabled.
Mar 9 12:34:56 hailo10 kern.info kernel: rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
Mar 9 12:34:56 hailo10 kern.info kernel: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
Mar 9 12:34:56 hailo10 kern.info kernel: NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
Mar 9 12:34:56 hailo10 kern.info kernel: GICv3: 160 SPIs implemented
Mar 9 12:34:56 hailo10 kern.info kernel: GICv3: 0 Extended SPIs implemented
Mar 9 12:34:56 hailo10 kern.info kernel: GICv3: Distributor has no Range Selector support
Mar 9 12:34:56 hailo10 kern.info kernel: Root IRQ handler: gic_handle_irq
Mar 9 12:34:56 hailo10 kern.info kernel: GICv3: 16 PPIs implemented
Mar 9 12:34:56 hailo10 kern.info kernel: GICv3: CPU0: found redistributor 0 region 0:0x0000000060680000
Mar 9 12:34:56 hailo10 kern.info kernel: ITS [mem 0x60620000-0x6062ffff]
Mar 9 12:34:56 hailo10 kern.info kernel: ITS@0x0000000060620000: allocated 8192 Devices@82030000@82030000 (flat, esz 8, psz 64K, shr 0)
Mar 9 12:34:56 hailo10 kern.info kernel: ITS: using cache flushing for cmd queue
Mar 9 12:34:56 hailo10 kern.info kernel: GICv3: using LPI property table@0x0000000082040000@0x0000000082040000
Mar 9 12:34:56 hailo10 kern.info kernel: GIC: using cache flushing for LPI property table
Mar 9 12:34:56 hailo10 kern.info kernel: GICv3: CPU0: using allocated LPI pending table@0x0000000082050000@0x0000000082050000
Mar 9 12:34:56 hailo10 kern.info kernel: kfence: initialized - using 2097152 bytes for 255 objects at 0x(ptrval)-0x(ptrval)
Mar 9 12:34:56 hailo10 kern.notice kernel: random: get_random_bytes called from start_kernel+0x480/0x660 with crng_init=0
Mar 9 12:34:56 hailo10 kern.info kernel: arch_timer: cp15 timer(s) running at 25.00MHz (virt).
Mar 9 12:34:56 hailo10 kern.info kernel: clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x5c40939b5, max_idle_ns: 440795202646 ns
Mar 9 12:34:56 hailo10 kern.info kernel: sched_clock: 56 bits at 25MHz, resolution 40ns, wraps every 4398046511100ns
Mar 9 12:34:56 hailo10 kern.info kernel: Console: colour dummy device 80x25
Mar 9 12:34:56 hailo10 kern.info kernel: printk: console [tty0] enabled
Mar 9 12:34:56 hailo10 kern.info kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 50.00 BogoMIPS (lpj=100000)
Mar 9 12:34:56 hailo10 kern.info kernel: pid_max: default: 32768 minimum: 301
Mar 9 12:34:56 hailo10 kern.info kernel: LSM: Security Framework initializing
Mar 9 12:34:56 hailo10 kern.info kernel: Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
Mar 9 12:34:56 hailo10 kern.info kernel: Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
Mar 9 12:34:56 hailo10 kern.info kernel: rcu: Hierarchical SRCU implementation.
Mar 9 12:34:56 hailo10 kern.info kernel: Platform MSI: msi-controller@60620000 domain created
Mar 9 12:34:56 hailo10 kern.info kernel: smp: Bringing up secondary CPUs …
Mar 9 12:34:56 hailo10 kern.info kernel: Detected VIPT I-cache on CPU1
Mar 9 12:34:56 hailo10 kern.info kernel: GICv3: CPU1: found redistributor 1 region 0:0x00000000606a0000
Mar 9 12:34:56 hailo10 kern.info kernel: GICv3: CPU1: using allocated LPI pending table@0x0000000082060000@0x0000000082060000
Mar 9 12:34:56 hailo10 kern.info kernel: CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
Mar 9 12:34:56 hailo10 kern.info kernel: Detected VIPT I-cache on CPU2
Mar 9 12:34:56 hailo10 kern.info kernel: GICv3: CPU2: found redistributor 2 region 0:0x00000000606c0000
Mar 9 12:34:56 hailo10 kern.info kernel: GICv3: CPU2: using allocated LPI pending table@0x0000000082070000@0x0000000082070000
Mar 9 12:34:56 hailo10 kern.info kernel: CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
Mar 9 12:34:56 hailo10 kern.info kernel: Detected VIPT I-cache on CPU3
Mar 9 12:34:56 hailo10 kern.info kernel: GICv3: CPU3: found redistributor 3 region 0:0x00000000606e0000
Mar 9 12:34:56 hailo10 kern.info kernel: GICv3: CPU3: using allocated LPI pending table@0x0000000082080000@0x0000000082080000
Mar 9 12:34:56 hailo10 kern.info kernel: CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
Mar 9 12:34:56 hailo10 kern.info kernel: smp: Brought up 1 node, 4 CPUs
Mar 9 12:34:56 hailo10 kern.info kernel: SMP: Total of 4 processors activated.
Mar 9 12:34:56 hailo10 kern.info kernel: CPU features: detected: 32-bit EL0 Support
Mar 9 12:34:56 hailo10 kern.info kernel: CPU features: detected: CRC32 instructions
Mar 9 12:34:56 hailo10 kern.info kernel: CPU: All CPU(s) started at EL1
Mar 9 12:34:56 hailo10 kern.info kernel: alternatives: patching kernel code
Mar 9 12:34:56 hailo10 kern.info kernel: devtmpfs: initialized
Mar 9 12:34:56 hailo10 kern.warn kernel: KASLR disabled due to lack of seed
Mar 9 12:34:56 hailo10 kern.info kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
Mar 9 12:34:56 hailo10 kern.info kernel: futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
Mar 9 12:34:56 hailo10 kern.info kernel: pinctrl core: initialized pinctrl subsystem
Mar 9 12:34:56 hailo10 kern.info kernel: NET: Registered PF_NETLINK/PF_ROUTE protocol family
Mar 9 12:34:56 hailo10 kern.info kernel: DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
Mar 9 12:34:56 hailo10 kern.info kernel: audit: initializing netlink subsys (disabled)
Mar 9 12:34:56 hailo10 kern.notice kernel: audit: type=2000 audit(0.016:1): state=initialized audit_enabled=0 res=1
Mar 9 12:34:56 hailo10 kern.info kernel: thermal_sys: Registered thermal governor ‘step_wise’
Mar 9 12:34:56 hailo10 kern.info kernel: thermal_sys: Registered thermal governor ‘power_allocator’
Mar 9 12:34:56 hailo10 kern.info kernel: cpuidle: using governor menu
Mar 9 12:34:56 hailo10 kern.info kernel: hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
Mar 9 12:34:56 hailo10 kern.info kernel: ASID allocator initialised with 65536 entries
Mar 9 12:34:56 hailo10 kern.info kernel: hailo15-pinctrl 7c291000.pinctrl: pinctrl-hailo15 registered
Mar 9 12:34:56 hailo10 kern.info kernel: HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
Mar 9 12:34:56 hailo10 kern.info kernel: HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
Mar 9 12:34:56 hailo10 kern.info kernel: HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
Mar 9 12:34:56 hailo10 kern.info kernel: HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
Mar 9 12:34:56 hailo10 kern.info kernel: EDAC MC: Ver: 3.0.0
Mar 9 12:34:56 hailo10 kern.info kernel: clocksource: Switched to clocksource arch_sys_counter
Mar 9 12:34:56 hailo10 kern.info kernel: NET: Registered PF_INET protocol family
Mar 9 12:34:56 hailo10 kern.info kernel: IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
Mar 9 12:34:56 hailo10 kern.info kernel: tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
Mar 9 12:34:56 hailo10 kern.info kernel: TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
Mar 9 12:34:56 hailo10 kern.info kernel: TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
Mar 9 12:34:56 hailo10 kern.info kernel: TCP: Hash tables configured (established 32768 bind 32768)
Mar 9 12:34:56 hailo10 kern.info kernel: UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
Mar 9 12:34:56 hailo10 kern.info kernel: UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
Mar 9 12:34:56 hailo10 kern.info kernel: NET: Registered PF_UNIX/PF_LOCAL protocol family
Mar 9 12:34:56 hailo10 kern.info kernel: workingset: timestamp_bits=46 max_order=20 bucket_order=0
Mar 9 12:34:56 hailo10 kern.info kernel: io scheduler mq-deadline registered
Mar 9 12:34:56 hailo10 kern.info kernel: io scheduler kyber registered
Mar 9 12:34:56 hailo10 kern.info kernel: cmsdk-gpio 78200000.gpio: CMSDK GPIO chip registered
Mar 9 12:34:56 hailo10 kern.info kernel: cmsdk-gpio 78201000.gpio: CMSDK GPIO chip registered
Mar 9 12:34:56 hailo10 kern.info kernel: Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
Mar 9 12:34:56 hailo10 kern.info kernel: brd: module loaded
Mar 9 12:34:56 hailo10 kern.info kernel: phram: ramdisk0 device: 0x10000000 at 0x90000000 for erasesize 0x1
Mar 9 12:34:56 hailo10 kern.info kernel: device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
Mar 9 12:34:56 hailo10 kern.info kernel: arm-scmi firmware:scmi: SCMI Notifications - Core Enabled.
Mar 9 12:34:56 hailo10 kern.info kernel: arm-scmi firmware:scmi: SCMI Protocol v2.0 ‘hailo:hailo’ Firmware version 0x310001
Mar 9 12:34:56 hailo10 kern.info kernel: cpu cpu0: EM: created perf domain
Mar 9 12:34:56 hailo10 kern.info kernel: arm-scmi firmware:scmi: Hailo SCMI Protocol Version 0.49.1
Mar 9 12:34:56 hailo10 kern.info kernel: hailo-soc soc: scu version 1.8.0, uboot version 0.0.0, linux version 1.8.0
Mar 9 12:34:56 hailo10 kern.err kernel: ina2xx_precise 0-0040: INA2xx detection failed (manufacturer ID mismatch or read error): -121
Mar 9 12:34:56 hailo10 kern.warn kernel: ina2xx_precise: probe of 0-0040 failed with error -121
Mar 9 12:34:56 hailo10 kern.info kernel: device-mapper: init: waiting for all devices to be available before creating mapped devices
Mar 9 12:34:56 hailo10 kern.info kernel: device-mapper: verity: sha256 using implementation “sha256-arm64-neon”
Mar 9 12:34:56 hailo10 kern.info kernel: device-mapper: ioctl: dm-0 (dm-verity) is ready
Mar 9 12:34:56 hailo10 kern.info kernel: EXT4-fs (dm-0): mounted filesystem without journal. Opts: (null). Quota mode: disabled.
Mar 9 12:34:56 hailo10 kern.info kernel: VFS: Mounted root (ext4 filesystem) readonly on device 254:0.
Mar 9 12:34:56 hailo10 kern.info kernel: devtmpfs: mounted
Mar 9 12:34:56 hailo10 kern.info kernel: Freeing unused kernel memory: 1024K
Mar 9 12:34:56 hailo10 kern.info kernel: Run /sbin/init as init process
Mar 9 12:34:56 hailo10 kern.debug kernel: with arguments:
Mar 9 12:34:56 hailo10 kern.debug kernel: /sbin/init
Mar 9 12:34:56 hailo10 kern.debug kernel: with environment:
Mar 9 12:34:56 hailo10 kern.debug kernel: HOME=/
Mar 9 12:34:56 hailo10 kern.debug kernel: TERM=linux
Mar 9 12:34:56 hailo10 daemon.info kernel: udevd[98]: starting version 3.2.10
Mar 9 12:34:56 hailo10 kern.notice kernel: random: udevd: uninitialized urandom read (16 bytes read)
Mar 9 12:34:56 hailo10 daemon.info kernel: udevd[99]: starting eudev-3.2.10
Mar 9 12:34:56 hailo10 kern.warn kernel: hailo_pci_ep: loading out-of-tree module taints kernel.
Mar 9 12:34:56 hailo10 kern.notice kernel: hailo_pci_ep_driver 222000.hailo_pci_ep_driver: Probing module. driver version 5.1.1
Mar 9 12:34:56 hailo10 kern.notice kernel: hailo_pci_ep_driver 222000.hailo_pci_ep_driver: Probing: Enabled 64 bit dma
Mar 9 12:34:56 hailo10 kern.info kernel: hailo_pci_ep_driver 222000.hailo_pci_ep_driver: vDMA controller is initialized
Mar 9 12:34:56 hailo10 kern.info kernel: hailo_pci_ep_driver 222000.hailo_pci_ep_driver: Configured atr table
Mar 9 12:34:56 hailo10 kern.notice kernel: hailo_pci_ep_driver 222000.hailo_pci_ep_driver: Pcie Ep driver board type is 2
Mar 9 12:34:56 hailo10 kern.notice kernel: hailort-core-driver 5c000.integrated_nnc: Probing module. driver version 5.1.1
Mar 9 12:34:56 hailo10 kern.info kernel: hailort-core-driver 5c000.integrated_nnc: Firmware was loaded successfully
Mar 9 12:34:56 hailo10 kern.info kernel: hailort-core-driver 5c000.integrated_nnc: Initializing vDMA controller
Mar 9 12:34:56 hailo10 kern.info kernel: hailort-core-driver 5c000.integrated_nnc: assigned reserved memory node integrated_nnc_dma_cma,cma
Mar 9 12:34:56 hailo10 kern.notice kernel: hailort-core-driver 5c000.integrated_nnc: Mapped [mem 0x7c050000-0x7c0507ff] /integrated_nnc/vdma@0/channel-regs
Mar 9 12:34:56 hailo10 kern.notice kernel: hailort-core-driver 5c000.integrated_nnc: Mapped [mem 0x7c052000-0x7c053fff] /integrated_nnc/vdma@0/engine-regs
Mar 9 12:34:56 hailo10 kern.info kernel: hailort-core-driver 5c000.integrated_nnc: Did not detect interrupt-names entry for index 1, using default
Mar 9 12:34:56 hailo10 kern.notice kernel: hailort-core-driver 5c000.integrated_nnc: Mapped [mem 0x7c054000-0x7c0547ff] /integrated_nnc/vdma@1/channel-regs
Mar 9 12:34:56 hailo10 kern.notice kernel: hailort-core-driver 5c000.integrated_nnc: Mapped [mem 0x7c056000-0x7c057fff] /integrated_nnc/vdma@1/engine-regs
Mar 9 12:34:56 hailo10 kern.notice kernel: hailort-core-driver 5c000.integrated_nnc: Mapped [mem 0x7c058000-0x7c0587ff] /integrated_nnc/vdma@2/channel-regs
Mar 9 12:34:56 hailo10 kern.notice kernel: hailort-core-driver 5c000.integrated_nnc: Mapped [mem 0x7c05a000-0x7c05bfff] /integrated_nnc/vdma@2/engine-regs
Mar 9 12:34:56 hailo10 kern.notice kernel: hailort-core-driver 5c000.integrated_nnc: Probing: Enabled 64 bit dma
Mar 9 12:34:56 hailo10 kern.info kernel: hailort-core-driver 5c000.integrated_nnc: vDMA controller is initialized
Mar 9 12:34:56 hailo10 kern.info kernel: hailort-core-driver 5c000.integrated_nnc: Allocated memory from device tree memory region starting physical address: 0x8e000000, size: 0x2000000
Mar 9 12:34:56 hailo10 kern.info kernel: hailo_pci_ep_driver 222000.hailo_pci_ep_driver: Changed device state to D3hot
Mar 9 12:34:56 hailo10 kern.info kernel: EXT4-fs (dm-0): re-mounted. Opts: (null). Quota mode: disabled.
Mar 9 12:34:56 hailo10 authpriv.err getty[286]: /dev/ttyS1: not a tty
Mar 9 12:34:56 hailo10 user.info HailoRT-Server: [server_main.cpp:82] [main] Using PCIe
Mar 9 12:35:00 hailo10 kern.info kernel: SCU booted from: PCIe
Mar 9 12:35:00 hailo10 kern.info kernel: sp805-wdt 7c2c1000.watchdog: registration successful
Mar 9 12:35:06 hailo10 authpriv.err getty[297]: /dev/ttyS1: not a tty
Mar 9 12:35:16 hailo10 authpriv.err getty[300]: /dev/ttyS1: not a tty
Mar 9 12:35:26 hailo10 authpriv.err getty[303]: /dev/ttyS1: not a tty
Mar 9 12:35:36 hailo10 authpriv.err getty[306]: /dev/ttyS1: not a tty
Mar 9 12:35:46 hailo10 authpriv.err getty[309]: /dev/ttyS1: not a tty
Mar 9 12:35:56 hailo10 authpriv.err getty[312]: /dev/ttyS1: not a tty
Mar 9 12:36:06 hailo10 authpriv.err getty[315]: /dev/ttyS1: not a tty
Mar 9 12:36:16 hailo10 authpriv.err getty[318]: /dev/ttyS1: not a tty
Mar 9 12:36:26 hailo10 authpriv.err getty[321]: /dev/ttyS1: not a tty
Mar 9 12:36:36 hailo10 daemon.info init: Id “S1” respawning too fast: disabled for 5 minutes
Mar 9 12:37:45 hailo10 kern.info kernel: hailo_pci_ep_driver 222000.hailo_pci_ep_driver: Changed device state to D0
Mar 9 12:37:45 hailo10 user.info HailoRT-Server: [device.cpp:53] [Device] OS Version: Linux 5.15.325.15.32-yocto-standard-01576-g55eda3b378bf #1 SMP PREEMPT Wed Oct 29 18:22:56 UTC 2025 aarch64
Mar 9 12:37:45 hailo10 user.info HailoRT-Server: [control.cpp:102] [control__parse_identify_results] firmware_version is: 5.1.1
Mar 9 12:37:45 hailo10 kern.info kernel: hailo_pci_ep_driver 222000.hailo_pci_ep_driver: Changed device state to D3hot
Mar 9 12:39:54 hailo10 kern.info kernel: hailo_pci_ep_driver 222000.hailo_pci_ep_driver: Changed device state to D0
Mar 9 12:39:54 hailo10 user.info HailoRT-Server: [vdevice.cpp:227] [create] Creating vdevice with params: device_count: 1, scheduling_algorithm: ROUND_ROBIN, multi_process_service: false
Mar 9 12:39:54 hailo10 user.info HailoRT-Server: [device.cpp:53] [Device] OS Version: Linux 5.15.325.15.32-yocto-standard-01576-g55eda3b378bf #1 SMP PREEMPT Wed Oct 29 18:22:56 UTC 2025 aarch64
Mar 9 12:39:54 hailo10 user.info HailoRT-Server: [control.cpp:102] [control__parse_identify_results] firmware_version is: 5.1.1
Mar 9 12:39:54 hailo10 user.info HailoRT-Server: [vdevice.cpp:367] [create] VDevice Infos: [integrated]
Mar 9 12:39:55 hailo10 user.err HailoRT-Server: [rpc_connection.cpp:49] [read_message] CHECK failed - Invalid magic! 4294832384 != 2320843826
Mar 9 12:39:55 hailo10 user.err HailoRT-Server: [hef.cpp:729] [parse_hef_memview] CHECK failed - HEF proto xxhash does not match
Mar 9 12:39:55 hailo10 user.err HailoRT-Server: [hef.cpp:1082] [Impl] Failed parsing HEF buffer
Mar 9 12:39:55 hailo10 user.err HailoRT-Server: [server.cpp:145] [handle_client_request] CHECK_SUCCESS failed with status=HAILO_INTERNAL_FAILURE(8)
Mar 9 12:39:55 hailo10 user.err HailoRT-Server: [hef.cpp:332] [create] Failed creating HEF
Mar 9 12:39:55 hailo10 user.err HailoRT-Server: [server.cpp:126] [serve_client] handle request failed with status: HAILO_INTERNAL_FAILURE(8)
Mar 9 12:39:55 hailo10 user.err HailoRT-Server: [hef.cpp:177] [create] CHECK_SUCCESS failed with status=HAILO_HEF_FILE_CORRUPTED(91)
Mar 9 12:39:55 hailo10 user.err HailoRT-Server: [vdevice.cpp:484] [create_infer_model] CHECK_SUCCESS failed with status=HAILO_HEF_FILE_CORRUPTED(91)
Mar 9 12:39:55 hailo10 user.err HailoRT-Server: [hailort_server.cpp:226] [do_action] CHECK_SUCCESS failed with status=HAILO_HEF_FILE_CORRUPTED(91)
Mar 9 12:39:55 hailo10 kern.info kernel: hailo_pci_ep_driver 222000.hailo_pci_ep_driver: Changed device state to D3hot
Mar 9 12:40:36 hailo10 kern.info kernel: hailo_pci_ep_driver 222000.hailo_pci_ep_driver: Changed device state to D0
Mar 9 12:40:36 hailo10 user.info HailoRT-Server: [vdevice.cpp:227] [create] Creating vdevice with params: device_count: 1, scheduling_algorithm: NONE, multi_process_service: false
Mar 9 12:40:36 hailo10 user.info HailoRT-Server: [device.cpp:53] [Device] OS Version: Linux 5.15.325.15.32-yocto-standard-01576-g55eda3b378bf #1 SMP PREEMPT Wed Oct 29 18:22:56 UTC 2025 aarch64
Mar 9 12:40:36 hailo10 user.info HailoRT-Server: [control.cpp:102] [control__parse_identify_results] firmware_version is: 5.1.1
Mar 9 12:40:36 hailo10 user.info HailoRT-Server: [vdevice.cpp:367] [create] VDevice Infos: [integrated]
Mar 9 12:40:36 hailo10 kern.info kernel: hailo_pci_ep_driver 222000.hailo_pci_ep_driver: Changed device state to D3hot
