Hailo 10H: Measure Power Draw
Hi everyone,
I’m trying to measure the power draw of a Hailo 10H m.2 module. I tried using the hailort 5.2.0 Docker but get the following error:
root@50b6b087320e:/local/workspace# hailortcli fw-control identify
Executing on device: 0000:57:00.0
Identifying board
Control Protocol Version: 2
Firmware Version: 5.2.0 (release,app)
Logger Version: 0
Device Architecture: HAILO10H
root@50b6b087320e:/local/workspace# hailortcli measure-power
[HailoRT CLI] [error] CHECK_SUCCESS failed with status=HAILO_OPEN_FILE_FAILURE(13)
Failed power measurement, status HAILO_OPEN_FILE_FAILURE(13)
Failed to execute on device: 0000:57:00.0. status= HAILO_OPEN_FILE_FAILURE(13)
Does the Hailo 10H currently support power measurement?
Best Regards
Thanks in advance!
Hi @Jona_Gass,
To measure power, make sure you’re running a network, power consumption will depend on the specific model you choose.
You can use:
hailortcli –-measure-power run2 set-net HEF
Just note that your H10h board needs to have an INA for this measurement to work.
Hi @nina-vilela ,
Thanks for the response! I’ll try that
How can i find out if my H10h board has an INA?
If so, how could I measure power consumption during LLM interference via hailo-ollama?
We wanted to check power consumption on Hailo 10h M2 Module (HM22HB1C2FAE) just like we did with Hailo 8 modules but couldn’t succeed for now.
In another post measure power consumption - General Discussion - Hailo Community, @user1232 provided a good overview of what to expect feature-wise.
Since the new Raspberry Pi AI Hat 2 was announced, it would be nice to have such an overview also for the 10H. Could that be added here? Also I am wondering why this is not part of the datasheet of the module?
Thanks!
EDIT:
just saw this command withthe extended flag in another post and checked. Seems like (at least for my module) Power measurement is not available, since it is no given in the “supported features” list, which is really unfortunate.
I guess that this is a “missing INA” topic? Or is that just not supported by the drivers (yet)?
I’ve updated the command in my previous answer so it’s compatible with Hailo‑10h.
To check if the INA is available, you can use the command that @alex_h shared (thanks, Alex!).
Another simple way is to just run the measurement command I sent, if the INA isn’t supported, you’ll get something like:
HailoRT CLI] [error] CHECK failed - Power measurement not supported. Disable the measure-power option
[HailoRT CLI] [error] CHECK_SUCCESS failed with status=HAILO_INVALID_OPERATION(6)
For the LLM networks, the command stays the same, you just need to provide the relevant HEF file.
Thanks a lot, i think that answers my Question :slight_smile:
Quick update: The Hailo-10H M.2 Starter Kit comes with a M.2 module that has the INA device for power measurement populated. It should be available at our distributors for order in a day or two.
