Hailo-10H / DFC v5.3.0: a16_w16 on a transformer encoder is not a blanket allocator wall — it's a 3-stage cascade (attention crash → a16-conv nan exponent → needs super-defuse). What is the intended 16-bit path?
This is a follow-up to my earlier post “Transformer encoders do compile on DFC v5.3.0 — the LayerNorm-decomposition wall is a 3D-vs-4D calibration mismatch.” In that post I claimed the 16-bit path was blocked because “any a16_w16 layer crashes the backend allocator.” After a much deeper pass, that claim is wrong, and I want to correct it and ask Hailo for the intended path.
Short version: 16-bit is not categorically rejected — a16_w16 on a benign (non-attention) layer compiles fine. Instead, pushing a full encoder toward 16-bit activations hits three different walls in sequence, each of which I can characterize precisely. I never reached a valid 16-bit HEF, so I also cannot yet report whether 16-bit even recovers the retrieval quality the 8-bit HEF loses.
Environment
  • Raspberry Pi 5 (aarch64, 16 GB) + Hailo-10H (8 GB LPDDR4), HailoRT v5.3.0
  • Compile host: x86_64, DFC (hailo_sdk_client) v5.3.0 from hailo_ai_sw_suite_2026-04:1, TF 2.19.1, Python 3.10, CPU only
  • Model: sentence-transformers/paraphrase-multilingual-MiniLM-L12-v2 (XLM-R, 12 layers, hidden 384, seq 256) — a sentence-embedding encoder
  • Parsed HN: 225 layers — 72 conv, 50 normalization, 37 ew_add, 25 layer_normalization, 24 matmul, 12 softmax
1. Correction: 16-bit is not categorically rejected
Applying a16_w16 to a single benign conv (conv72, the last FFN output projection, far from any attention op) compiles end-to-end on a stock SDK:
[info] multilingual_..._v2 Successful Partition and Allocation (duration: 8m 05s)
[info] multilingual_..._v2 Successful Kernel Compilation (duration: 4s)
[info] multilingual_..._v2 Successful Compilation (duration: 8m 20s)
-> HEF 20.4 MB
So the allocator does not reject 16-bit per se. My earlier “any a16_w16 crashes” conclusion was an artifact of the fact that all four of my original 16-bit configs put the 16-bit on the attention softmax. The real picture is a cascade.
Stage Where 16-bit is applied Failure
Wall 1 a16_w16 on attention (softmax) BackendAllocatorException: ... unexpected crash (in compile())
Wall 2 a16 on conv layers nan exponent in conv_low_sub_layer/act_op (in optimize())
Wall 3 16-bit activations on full-width layers ... needs super-defuse (in compile())
2. Wall 1 — a16_w16 on attention → allocator crash
With 16-bit on the attention softmax, compile() crashes after finding valid partitions:
This is the same failure reported for a LightGlue self-attention block in Compiling with 16-bit inputs crashes (that thread is unresolved). Keeping softmax and the attention matmuls at 8-bit avoids it — which is what let me get past this wall and reach Wall 2.
3. Wall 2 — a16 on convs → nan exponent in the low sub-layer
Applying a16_w8 broadly (16-bit activations, 8-bit weights) dies in optimize(), first as:
File ".../acceleras/lossy_elements/quant_element.py", line 248, in a_b_factorize
    b_fac = np.arange(max(np.floor(target / max_a), 1), max_b + 1)
ValueError: arange: cannot compute length
and, if that factorization is guarded, as:
hailo_model_optimization.acceleras.utils.acceleras_exceptions.AccelerasNegativeSlopesError:
the exponent [[nan]] is not in range [ 7 22] for layer
multilingual_..._v2/conv4/conv_low_sub_layer/act_op
What’s happening: the a16 conv decomposition splits each conv into a high and a low sub-layer. For this model, the low sub-layer’s scale computes to zero → exponent nan. Instrumenting a full pass shows this is true for all 72 conv low sub-layers — i.e. every conv’s weights are representable in the high 8-bit part, so the low residual is ≈0. (A useful implication: a16_w8 here is effectively 16-bit activations + 8-bit weights.)
It is not a calibration artifact. The degenerate set is unstable across calibration sets, and it persists with optimization_level=1 and with real, diverse calibration text (2,500 vault paragraphs). So richer calibration does not fix it.
I could only get past this with a runtime monkey-patch (not a supported path — flagging it only because it reveals Wall 3): force the degenerate low sub-layers to contribute exactly zero — check_exp_range → warn instead of raise, and nan_to_num(...) on the exported weights. With that, optimize() completes cleanly with 16-bit activations:
[H] optimize OK. sanitized low-sublayers: 72
4. Wall 3 — 16-bit activations → needs super-defuse on norm / elementwise
With optimize() done, compile() then fails:
[error] Failed to optimize bucket_0 with error: Assignment of normalization1 needs super-defuse
[error] BackendAllocatorException: Compilation failed: Assignment of normalization1 needs super-defuse
Setting the normalization layers back to a8_w8 just moves the same failure to the next wide layer:
[error] BackendAllocatorException: Compilation failed: Assignment of mul_and_add1 needs super-defuse
Interpretation: a full-width 16-bit activation tensor ([SEQ=256, HIDDEN=384]) exceeds a single resource assignment and needs to be super-defused. But DefuseType (.../script_parser/commands.py) only exposes conv variants — SUPER_CONV, SUPER_DW, SUPER_DECONV — so normalization / mul_and_add / elementwise layers appear to have no applicable super-defuse, and the allocator errors out instead of splitting them. Excluding one just exposes the next.
Net result: 16-bit activations do not compile for this encoder at SEQ=256 on DFC v5.3.0. I never obtained a valid 16-bit HEF, so the open quality question — does 16-bit recover the retrieval the 8-bit HEF loses (70.8% top-1 vs 100% FP32) — remains unmeasured.
5. What I tried (14 compiles, summarized)
  • a16_w16 on one benign conv → compiles (§1).
  • a16_w16 / a16_w8 on attention → Wall 1.
  • a16_w8 global, optimization_level 0 and 1, synthetic and real vault calibration → Wall 2 (nan), calibration-independent.
  • Per-layer exclusion of degenerate convs → whack-a-mole; the set shifts with calibration.
  • Runtime sanitize of degenerate low sub-layers → optimize() passes → Wall 3.
  • Exclude normalization from 16-bit → Wall 3 moves to mul_and_add.
6. Questions / requests for Hailo
  1. What is the intended way to compile 16-bit activations for a transformer encoder on the Hailo-10H? Is a16_w16/a16_w8 on the attention softmax/matmul expected to crash the allocator (Wall 1), and is there a supported config that lets 16-bit attention through — or is that only fixed in a later DFC?
  2. The a16 conv low sub-layer nan exponent (Wall 2): is a zero-valued low residual (weights fully representable in the high 8-bit part) a known degenerate case? Is there a supported directive to make such a low sub-layer contribute zero, rather than a user-side patch?
  3. needs super-defuse on normalization / mul_and_add (Wall 3): is there a supported way to (super-)defuse wide 16-bit non-conv layers — e.g. an allocator_param / compilation_param to enable automatic super-defuse — or is reducing SEQ the only option to bring the 16-bit activation footprint under the threshold?
  4. Is any of the above resolved in a DFC newer than v5.3.0 (hailo_ai_sw_suite_2026-04)?
Environment: RPi5 (aarch64) + Hailo-10H, HailoRT 5.3.0; compile host x86_64, DFC v5.3.0 (hailo_ai_sw_suite_2026-04:1), TF 2.19.1, CPU-only. Model: paraphrase-multilingual-MiniLM-L12-v2 (XLM-R, 12 layers, seq 256).
If you need more info please, let me know
Thanks!
Hi ! I actually worked on trying to compile a LLM on hailo10h: I compiled an LLM for the hailo-10h let met know if I can help you !
Hi Leo — thanks for the pointer, and congrats on getting the LLM flow that far. I went through your repo carefully and it paid off in one unexpected way, so here’s what I found in return, plus one direct question.
1. Your use_saitama=True, device=cuda trick makes the RTX usable for encoders on DFC 5.3.0.
I’d been stuck compiling CPU-only: the Suite’s TF 2.19.1 can’t JIT for sm_120 (CUDA_ERROR_INVALID_HANDLE [Op:AddV2]), and swapping TF is impossible because HSim.so is ABI-linked to TF 2.19.1. Your PyTorch-engine route sidesteps all of that. Measured on paraphrase-multiling ual-MiniLM-L12-v2 (12-layer XLM-R encoder, SEQ=256, 1024 real calibration samples):
Path optimize() retrieval top-1 (12 ES/EN pairs, SDK_BIT_EXACT)
TF, CPU 6.5 min 58.3%
Saitama, RTX 5090 2.0 min 58.3%
Same quantized result, 3× faster. Two things worth adding to your notes: (a) hide the GPU from TF (tf.config.set_visible_devices([], "GPU")) before importing the SDK, otherwise TF’s broken JIT still crashes; (b) SDK_BIT_EXACT emulation is TF-only, so run evaluation with TF
on CPU.
2. Every accuracy-recovery stage destroys retrieval on an embedding encoder. This extends your “finetune + bias_correction is catastrophic” finding — for embeddings, even bias_correction alone is:
Recipe (all 8-bit, opt_level=0 base) top-1 corr vs FP32
equalization only 58.3% 0.176
+ finetune (4 epochs) 16.7% 0.120
+ bias_correction, Saitama/GPU 4.2% 0.094
+ bias_correction, TF/CPU (control) 8.3% 0.088
Same collapse on both engines, so it’s the algorithm, not Saitama. My reading: these stages minimize per-tensor error, which is fine for logits but wrecks the geometry of the embedding space that retrieval depends on. For encoders: optimization_level=0 and nothing else. (Si
de note: with finetune on, compile() also died with BackendAllocatorException: unexpected crash even in pure 8-bit; bias_correction alone compiled fine.)
3. The 16-bit walls are engine-independent. Re-ran both with Saitama on GPU:
  • a16_w16 on all attention softmax sub-layers → optimize() OK → compile(): BackendAllocatorException: Compilation failed with unexpected crash (Wall 1, unchanged).
  • a16_w8 on conv/normalization/ew_add → ValueError: arange: cannot compute length (Wall 2 nan exponent, unchanged).
    So the allocator crash lives downstream of quantization, in the native compiler — no Python-side recipe reaches it.
A gotcha for anyone targeting attention: softmax gets decomposed during optimize() into reduce_max_softmaxN / ew_sub_softmaxN / ne_activation_ew_sub_softmaxN / reduce_sum_softmaxN / ew_mult_softmaxN. quantization_param({softmax*}, ...) then matches *zero layers silently
  • (no error — the script is stored as quantization_param([], ...)), and naming softmax1 explicitly fails with “not found”. {*softmax*} is what actually applies it.
The question: in any graph you’ve compiled, did you ever get a16 activations through an attention block (softmax and/or the QK/AV matmuls) and past the allocator? Your a16_w16 on input_layer1 matches what I saw too (a 16-bit layer far from attention compiles fine), so
I’m specifically after the attention case — that’s the one nobody seems to have working on 5.3.0.
For what it’s worth, the Model Zoo moved to DFC 5.4.0 in July; I’ll re-run the three walls there as soon as I have it and report back.
Hi Fernando — this is genuinely useful, thanks for going through the repo and reporting back in such detail.
On your direct question: no, I haven’t gotten a16 through the attention block either. My own a16_w16 usage is limited to input_layer1 (the embedding input, far from attention — matches what you saw) and ew_add* layers on the encoder recipe. I’ve never pushed 16-bit through softmax or the QK/AV matmuls themselves, so I can’t confirm it’s possible on 5.3.0 — sounds like nobody has it working yet, as you suspected.
In return, one finding that might interest you given your accuracy-recovery results: on a causal LLM decoder (not an encoder), bias_correction alone — not combined with finetune — measurably improved cosine over native FP32 in my ablation. finetune combined with bias_correction was catastrophic for me too (cosine went negative). So my data points the same direction as yours on finetune, but the opposite direction on bias_correction alone. My read: whether accuracy-recovery stages help or hurt seems to depend on architecture class (causal decoder vs. bidirectional encoder) rather than being universal — logits vs. embedding-geometry, matches your own reading. I’ve written this up with attribution to your posts here: [link to the repo finding].
The tf.config.set_visible_devices([], "GPU") + SDK_BIT_EXACT-is-TF-only notes are exactly the kind of thing I’ll fold into my own docs too — thanks for those.
Would you be interested in working on this together more directly? The repo is public and open to contributions (hailo-10h-llm-compiler) — your encoder/attention-precision findings would be a genuinely valuable addition on their own (there’s already an Encoder-Models page citing your posts, but having you contribute directly rather than just being cited would be better), and the compiler-internals overlap between what you’re hitting on 16-bit attention and what I’m still fighting on the KV-cache decode side seems too close to be coincidence. Open to a PR, a standing thread, whatever works for you.
