Hello Hailo Community,
I am working with the following setup and would appreciate guidance on the correct workflow.
Current hardware / environment
Raspberry Pi 5
Raspberry Pi AI Kit (M.2 HAT+ with Hailo AI Module, Hailo-8 family)
Camera pipeline is already working
Object recognition with camera input is functional on the Raspberry Pi
Development host: Ubuntu 24.04 x86_64 with Docker-based Hailo AI Software Suite
What is working
The Hailo device is recognized
Camera-based object detection examples run successfully
ONNX → HEF compilation flow has been verified with simple test models
What I am trying to do
I am an echocardiographer and would like to test whether Hailo can distinguish anatomical structures in echocardiography.
Specifically:
PSAX (parasternal short-axis) echocardiography images
Classification or recognition of
AV (aortic valve)
PV (pulmonary valve)
The initial goal is not clinical-grade performance, but to verify whether this anatomical distinction is feasible on Hailo.
My understanding so far
To run a custom model on Hailo, an ONNX model is required as input to the Hailo compiler
The ONNX model must be created by training a neural network (e.g., classification or detection) on labeled images
Hailo itself does not provide medical or echocardiography-specific ONNX models
Questions
Is this understanding correct that a custom-trained ONNX model is required for this use case?
For a first attempt, would frame-level classification (PSAX_AV vs PSAX_PV) be the recommended approach over detection/segmentation?
Are there any reference ONNX models, operator constraints, or best practices recommended for Hailo when training and exporting ONNX models for custom image classification tasks?
Are there known limitations or considerations when using grayscale or ultrasound-like images with Hailo?
Any guidance, documentation pointers, or practical advice from similar use cases would be greatly appreciated.
Thank you in advance.
