I’m working on a Raspberry Pi 5 project with a USB camera, using GStreamer and Hailo8l for AI inference. I want to generate two UDP streams simultaneously from the same camera source:
- One stream with AI inference and overlay (port 6976)
- One raw stream without inference (port 6977)
Here’s the simplified Python GStreamer pipeline I’m using
# SOURCE (common)
source_pipeline = (
f'appsrc name=app_source is-live=true format=time do-timestamp=true max-buffers=3 leaky-type=downstream ! '
'videoflip method=horizontal-flip ! '
'videoconvert ! '
f'video/x-raw,format={self.video_format},width={self.video_width},height={self.video_height} ! '
f'{QUEUE(name="source_q", max_size_buffers=500)} ! '
'tee name=main_tee allow-not-linked=true'
# INFERENCE BRANCH (6976)
detection_pipeline = INFERENCE_PIPELINE(
hef_path=self.hef_path,
post_process_so=self.post_process_so,
post_function_name=self.post_function_name,
batch_size=self.batch_size,
config_json=self.labels_json,
additional_params=self.thresholds_str
detection_pipeline_wrapper = INFERENCE_PIPELINE_WRAPPER(detection_pipeline, name='inference_wrapper')
ia_branch = (
'main_tee. ! '
f'{QUEUE(name="ia_q", max_size_buffers=500)} ! '
f'{detection_pipeline_wrapper} ! '
f'{QUEUE(name="identity_q", max_size_buffers=500)} ! '
'identity name=identity_callback ! '
f'{QUEUE(name="hailopython_q", max_size_buffers=500)} ! '
'hailopython module=<path_to_module> function=run qos=false ! '
f'{QUEUE(name="overlay_q", max_size_buffers=500)} ! '
'hailooverlay font-thickness=2 line-thickness=4 show-confidence=true ! '
'videoconvert ! '
'openh264enc ! h264parse ! mpegtsmux ! rtpmp2tpay ! '
'udpsink host=127.0.0.1 port=6976 sync=false async=false'
# RAW BRANCH (6977)
raw_branch = (
'main_tee. ! '
f'{QUEUE(name="raw_q", max_size_buffers=500)} ! '
'videoconvert ! '
'video/x-raw,format=I420 ! '
'rtpvrawpay ! '
'udpsink host=127.0.0.1 port=6977 sync=false async=false'
# FULL PIPELINE
pipeline_string = f'{source_pipeline} {ia_branch} {raw_branch}'
print("=" * 60)
print("Active UDP streams:")
print(" • 6976 → Inference + overlay")
print(" • 6977 → Raw video")
print("=" * 60)
return pipeline_string
Problem:
- Only one UDP stream works at a time.
- If I disable the AI branch, the raw branch works.
- If I disable the raw branch, the AI branch works.
- CPU usage is fine.
- I tried
multiqueuefor the branches and increasedmax-size-buffers, but the result is the same. - No errors are printed.
I suspect the issue may still be related to the camera itself. I already know it doesn’t support being accessed twice simultaneously, but I thought using a tee should allow sharing a single access between the two branches.
Questions:
- Has anyone successfully streamed two UDP outputs from the same live camera with one branch doing AI inference?
- Is there a better way to share the camera feed so that both branches work simultaneously?
- Any recommended settings for
queue,multiqueue, orudpsinkto make this stable?
Thanks in advance for any advice!
