Hi
Just bought a rpi5 with ai hat+(26) for some personal trials on cv. I did some cv development on earlier rpi models and it was ok then. Now with this new toy I’m expecting a great leap for my development tests.
Unfortunately t took me two days to properly configure the hardware, stock images didn’t help and finding the right info and package is a little but confusing. Anyway I visited all possible methods (deb packages, apt repositories, compile from source, gits, forums, ai agents etc) and now I have a working hardware with 6.12 kernel, 4.23 hailort and 3.12 python. I’m using a headless setup with remote vscode dev environment. I started with a basic cv code I’ve been working on on another platform. I modified the code to include hailort support for processing. And before my first run when I install the requirements on venv via pip, I encountered a strange message where hailort requires numpy < 2 where opencv install 2.2. My guess I’m on the wrong side of the dependency wars. I just need somebody to point me the right direction where I can focus on my code instead of this holy wars. Any help is appreciated. Thanks…
Here is the description of my current situation:
rpi5dev@rpi5-dev:~/silX $ hailortcli fw-control identify
Identifying board
Control Protocol Version: 2
Firmware Version: 4.23.0 (release,app,extended context switch buffer)
Logger Version: 0
Board Name: Hailo-8
Device Architecture: HAILO8
rpi5dev@rpi5-dev:~/silX $ source venv/bin/activate
((venv) ) rpi5dev@rpi5-dev:~/silX $ cd age-genderX/
((venv) ) rpi5dev@rpi5-dev:~/silX/age-genderX $ pip install -r requirements.txt
Collecting opencv-python-headless (from -r requirements.txt (line 1))
Using cached opencv_python_headless-4.12.0.88-cp37-abi3-manylinux2014_aarch64.manylinux_2_17_aarch64.whl.metadata (19 kB)
Requirement already satisfied: numpy in /home/rpi5dev/silX/venv/lib/python3.12/site-packages (from -r requirements.txt (line 2)) (1.26.4)
Collecting numpy (from -r requirements.txt (line 2))
Using cached numpy-2.2.6-cp312-cp312-manylinux_2_17_aarch64.manylinux2014_aarch64.whl.metadata (63 kB)
Using cached opencv_python_headless-4.12.0.88-cp37-abi3-manylinux2014_aarch64.manylinux_2_17_aarch64.whl (33.1 MB)
Using cached numpy-2.2.6-cp312-cp312-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (14.0 MB)
Installing collected packages: numpy, opencv-python-headless
Attempting uninstall: numpy
Found existing installation: numpy 1.26.4
Uninstalling numpy-1.26.4:
Successfully uninstalled numpy-1.26.4
ERROR: pip’s dependency resolver does not currently take into account all the packages that are installed. This behaviour is the source of the following dependency conflicts.
hailort 4.23.0 requires numpy<2, but you have numpy 2.2.6 which is incompatible.
Successfully installed numpy-2.2.6 opencv-python-headless-4.12.0.88
[notice] A new release of pip is available: 25.0.1 → 25.3
[notice] To update, run: pip install --upgrade pip
((venv) ) rpi5dev@rpi5-dev:~/silX/age-genderX $ python3.12 console_app.py
Model yükleniyor: models/face_attr.hef …
Model Shape Raw: (218, 178, 3)
Model Hazır! Giriş Boyutu: 178x218
KRİTİK HATA: Model yüklenemedi.
Detay: ‘ConfiguredNetwork’ object has no attribute ‘create_params_dict_by_name_with_group_params’
