setting user_data.use_frame = True
is NOT showing any user frame.
the rpi 5 i am using IS NOT strong enough to handle frame save at 30 fps. not even with a sdd.
but for a lot off apps. text output is fine.
but please make a flow diagram over the source file connections so we can easily change the behavior of the stream that fits our needs.
