Dear Hailo community members,
I have the Hailo-15 AI Vision Processor board. I updated the wic file with the TFTP option available in the firmware when booting up the board. The update seemed to be without errors. After resetting the board, it prints this messages and then resets itself in a loop:
U-Boot SPL 2022.01 (Jun 16 2024 - 07:49:26 +0000)
Loading Environment from SPIFlash... OK
U-Boot SPL boot source mmc2
## Checking hash(es) for config config_1 ... sha256,rsa3072:customer+ OK
## Checking hash(es) for Image atf ... sha256+ OK
## Checking hash(es) for Image uboot ... sha256+ OK
NOTICE: BL31: v2.9(release):3d54637-dirty
NOTICE: BL31: Built : 14:31:00, Sep 15 2024
U-Boot 2022.01 (Sep 15 2024 - 14:27:28 +0000)
DRAM: 4 GiB
In: uart@00109000
Out: uart@00109000
Err: uart@00109000
DRAM: 4 GiB
hailo15 pinctrl registered
WDT: Started watchdog@7c2c1000 with servicing (60s timeout)
MMC: sdio1@78001000: 1
Loading Environment from SPIFlash... jedec_spi_nor flash@0: unrecognized JEDEC id bytes: 9d, 70, 19
*** Warning - spi_flash_probe_bus_cs() failed, using default environment
In: uart@00109000
Out: uart@00109000
Err: uart@00109000
Firmware version mismatch: u-boot(binary)=0x2a0004, fw=0x2a0000
initcall sequence 000000017ffd6528 failed at call 00000000830026ec (err=-1)
Has anyone run into a similar issue? Or is there someone who has a working SD card image and could share it with me?
Thank you.
Best regards,
David
