Runtime Crash: Assertion !this->empty() failed in STL queue (Hailo SDK)
Hi team,
While running inference with the Hailo SDK using run_async(), I’m getting the following runtime crash from the C++ backend:
/usr/include/c++/12/bits/stl_queue.h:235:
std::queue<_Tp, _Sequence>::reference std::queue<_Tp, _Sequence>::front()
[with _Tp = std::unique_ptr;
_Sequence = std::deque<std::unique_ptr, std::allocatorstd::unique_ptr>;
reference = std::unique_ptr&]:
Assertion ‘!this->empty()’ failed.
It seems like the SDK is trying to pop from an empty internal request queue. This happens intermittently during inference, especially after trying to reuse a Bindings object or not syncing properly between run_async() and wait().
Questions:
Is this a known issue with the async inference API?
Should we avoid reusing
Bindings()objects? -
Is there a safe pattern to queue requests and retrieve results without hitting this race condition?
Any guidance or examples on proper async inference usage would be appreciated.
Thanks!
