error occured when optimize the har file.
I parsed an onnx file to har file using the command below;
hailomz parse --hw-arch hailo8 --ckpt ./yolov8_classification.onnx yolov8n
then I ran optimize command as below and the error was shown. What is the problem and how should I fix the error?
hailomz optimize yolov8n --har ./yolov8n.har --calib-path ./classification/train/ --classes -2
Start run for network yolov8n …
Preparing calibration data…
[info] Loading model script commands to yolov8n from /local/workspace/hailo_model_zoo/hailo_model_zoo/cfg/alls/generic/yolov8n.alls
[info] Loading model script commands to yolov8n from string
File “/local/workspace/hailo_virtualenv/bin/hailomz”, line 33, in
File “/local/workspace/hailo_model_zoo/hailo_model_zoo/main.py”, line 122, in main
run(args)
File “/local/workspace/hailo_model_zoo/hailo_model_zoo/main.py”, line 111, in run
return handlersargs.command
File “/local/workspace/hailo_model_zoo/hailo_model_zoo/main_driver.py”, line 225, in optimize
optimize_model(
File “/local/workspace/hailo_model_zoo/hailo_model_zoo/core/main_utils.py”, line 351, in optimize_model
optimize_full_precision_model(runner, calib_feed_callback, logger, model_script, resize, input_conversion, classes)
File “/local/workspace/hailo_model_zoo/hailo_model_zoo/core/main_utils.py”, line 337, in optimize_full_precision_model
runner.optimize_full_precision(calib_data=calib_feed_callback)
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/runner/client_runner.py”, line 2095, in optimize_full_precision
self._optimize_full_precision(data_continer)
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/runner/client_runner.py”, line 2098, in _optimize_full_precision
self._sdk_backend.optimize_full_precision(data_continer)
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/sdk_backend.py”, line 1664, in optimize_full_precision
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/sdk_backend.py”, line 1549, in _apply_model_modification_commands
command.validate_command([layer.name for layer in model])
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/script_parser/model_modifications_commands.py”, line 452, in validate_command
raise AllocatorScriptParserException(f"Given layers {self._layer} not exist in the HN")
Hey @Seungdae_Kim,
The issue is that you’re trying to optimize a YOLOv8 classification model but using the default yolov8n configuration, which is for object detection. The detection config includes NMS post-processing and layer references that don’t exist in your classification model, causing the “Given layers not exist in the HN” error.
The fix: Don’t pass the model name (yolov8n) when working with custom models. Instead, create a custom YAML file for your classification model (without the detection-specific stuff like NMS).
I’d recommend following Victor’s approach from this thread and using the single compile command:
hailomz compile --ckpt yolov8_classification.onnx \
    --calib-path /path/to/calibration/imgs/ \
    --yaml custom_yolov8_classification.yaml \
    --hw-arch hailo8 \
    --classes <number_of_classes>
This handles parsing, optimization, and compilation in one step. Just make sure your custom YAML is configured for classification, not detection.
The key takeaway: avoid using the default yolov8n name when your model has a different architecture - it’ll load incompatible configurations.
Hope this helps!
