ERROR | Hailo-10H first installation on Windows 10 Pro
Hi everyone,
I’m new here and looking for some help installing my new Hailo-10H.
System Specifications
  • OS: Windows 10 Pro 22H2 (Build 19045.6466)
  • Motherboard: ASRock X99 Extreme4
  • CPU: Intel Xeon E5-2699 v3
  • RAM: 128 GB
  • GPUs: 1x NVIDIA P6000 + 1x NVIDIA GP100
  • PSU: 1 kW
(Note: My current configuration runs engineering workloads with zero issues so far.)
The Problem
I’ve tried installing the Hailo-10H in two ways:
  1. Using a PCIe-to-M.2 converter in one of the free PCIe slots.
  2. Directly into the M.2 slot on the motherboard.
In both cases, I cannot get it to work. Windows Device Manager reports a “Code 10 - STATUS_DEVICE_POWER_FAILURE” error under the device properties.
Additionally, when attempting to install the HailoRT package, the installer rolls back near the end of the progress bar due to an internal error (no specific error code given). Ultimately, the Hailo suite fails to install, and the Code 10 error persists in Device Manager.
Does anyone have any ideas on what might be causing this or how to fix it?
Can you please post pictures of your Hailo-10H module? Is it a module from Hailo or from one of our partners?
Did you run the install with a Hailo-10H module connected or without?
Do you have secure boot disabled on your machine?
Thanks Klaus, I presume that the attached pictures in my initial post should answer most of your questions. The module is from Hailo and it was connected during the installation. I have no secure boot enabled.
Any idea what is happening ?
Can you try installing HailoRT without the device connected? I don’t have a Hailo-10H M.2 module with me at the moment (OOO). I did run the HailoRT_5.4.0_windows_installer.msi on my Windows 11 laptop, and the installation completed successfully.
Hi @Klaus_Koschinsky sorry for the late reply. I actually solved by installing FIRST an older version of the installer and THEN the latest one.
