Error during RFDETR conversion
I’m trying to convert the quite recent RFDETR from Roboflow and got this error during conversion:
[info] Translation started on ONNX model inference_model_sim
[info] Restored ONNX model inference_model_sim (completion time: 00:00:00.44)
[info] Extracted ONNXRuntime meta-data for Hailo model (completion time: 00:00:01.61)
[info] Simplified ONNX model for a parsing retry attempt (completion time: 00:00:05.93)
  File "/home/louis/Downloads/rf-detr-test/.venv/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/parser/parser.py", line 235, in translate_onnx_model
  File "/home/louis/Downloads/rf-detr-test/.venv/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/parser/parser.py", line 316, in _parse_onnx_model_to_hn
  File "/home/louis/Downloads/rf-detr-test/.venv/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/parser/parser.py", line 367, in parse_model_to_hn
  File "/home/louis/Downloads/rf-detr-test/.venv/lib/python3.10/site-packages/hailo_sdk_client/model_translator/translator.py", line 83, in convert_model
    self._create_layers()
  File "/home/louis/Downloads/rf-detr-test/.venv/lib/python3.10/site-packages/hailo_sdk_client/model_translator/edge_nn_translator.py", line 39, in _create_layers
    self._update_vertices_info()
  File "/home/louis/Downloads/rf-detr-test/.venv/lib/python3.10/site-packages/hailo_sdk_client/model_translator/onnx_translator/onnx_translator.py", line 217, in _update_vertices_info
    node.update_output_format()
  File "/home/louis/Downloads/rf-detr-test/.venv/lib/python3.10/site-packages/hailo_sdk_client/model_translator/onnx_translator/onnx_graph.py", line 475, in update_output_format
    self.output_format = self.get_matmul_layer_info()[-1]
  File "/home/louis/Downloads/rf-detr-test/.venv/lib/python3.10/site-packages/hailo_sdk_client/model_translator/onnx_translator/onnx_graph.py", line 4050, in get_matmul_layer_info
    elif pred1.op == "Transpose":
AttributeError: 'NoneType' object has no attribute 'op'
  File "/home/louis/Downloads/rf-detr-test/convert.py", line 36, in <module>
    main()
  File "/home/louis/Downloads/rf-detr-test/convert.py", line 15, in main
    _ = runner.translate_onnx_model(
  File "/home/louis/Downloads/rf-detr-test/.venv/lib/python3.10/site-packages/hailo_sdk_common/states/states.py", line 16, in wrapped_func
  File "/home/louis/Downloads/rf-detr-test/.venv/lib/python3.10/site-packages/hailo_sdk_client/runner/client_runner.py", line 1158, in translate_onnx_model
    parser.translate_onnx_model(
  File "/home/louis/Downloads/rf-detr-test/.venv/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/parser/parser.py", line 276, in translate_onnx_model
I struggle to understand the culprit of the issue.
To reproduce, here is the code I used for conversion:
from rfdetr import RFDETRBase
# Convert RFDETR to ONNX
model = RFDETRBase()
model.export()
# Convert model to HAILO8
runner = ClientRunner(hw_arch="hailo8")
    model="output/inference_model.onnx",
    net_name="rfdetr",
    start_node_names=["input"],
    end_node_names=["dets", "labels"],
    net_input_shapes={"input": (1, 3, 560, 560)},
Any help on that topic? The issue is still present in the last version of the HAILO Dataflow Compiler I used (3.32.0).
Deformable Attention is not supported by DFC.
The error message suggests that the issue is with a Transpose operation, not with attention or deformable attention. The message format also suggests that its a bug in DFC, not that the operator is not supported.
This could be great if the error message was clear about the issue. I suppose that deformable is expressed in terms of Gather and MatMul-like ops. The error message could mention those ops and what is not supported in them I think.
Will deformable attention be supported by DFC?
Thanks for your help.
Hi Louis ! Did you ever manage to convert this RFDETR model to .hef ?
Any updates? @Louis_Lac
@Antoine_Volard, @Nathan_Kau Unfortunately I’ve not been able to convert this model for HAILO inference for now.
Thanks for the update. Seems like nothing but basic CNNs work on HAILO
Yep. In my experience the HAILO-8 is very fast and efficient on CNN-like operations such as convolutions. It is quite slow when there is attention operations. Attention-based models are also harder to export to HAILO-8 because of calibration issues.
Hi @Louis_Lac - just checking in in case you ever got an answer / managed to get it to work?
