Hi, i’m tring to convert openpilot’s supercombo.onnx to hef, but something wrong.
My dfc_script.py:
import os
#Define model information
model_name = 'supercombo'
onnx_path = '/tmp/fp16_to_fp32.onnx'
start_node = ["input_imgs","big_input_imgs", "desire",
"traffic_convention","lateral_control_params",
"prev_desired_curv", "features_buffer"
end_node = "outputs"
input_shape = {
"input_imgs": [1,12,128,256],
"big_input_imgs": [1,12,128,256],
"desire": [1,100,8],
"traffic_convention": [1,2],
"lateral_control_params": [1,2],
"prev_desired_curv": [1,100,1],
'features_buffer': [1, 99,512]}
output_shape = {
"outputs": [1, 6504]
chosen_hw_arch = 'hailo8'
#alls_lines = [
# 'model_optimization_flavor(optimization_level=0, compression_level=1)\n',
# 'resources_param(max_control_utilization=1.0, max_compute_utilization=1.0,max_memory_utilization=1.0)\n',
# 'performance_param(fps=250)\n'
#Parsing
hn, npz = runner.translate_onnx_model(onnx_path, model_name, start_node_names=start_node, end_node_names=end_node, net_input_shapes=input_shape)
parsed_model_har_path = f'{model_name}_parsed_model.har'
runner.save_har(parsed_model_har_path)
#Optimize
#calibData = np.random.randint(0, 255, (1024, input_height, input_width, input_ch))
#runner.load_model_script(''.join(alls_lines))
#runner.optimize(calibData)
#quantized_model_har_path = f'{model_name}_quantized_model.har'
#runner.save_har(quantized_model_har_path)
#Compile
hef = runner.compile()
file_name = f'{model_name}.hef'
with open(file_name, 'wb') as f:
f.write(hef)
compiled_model_har_path = f'{model_name}_compiled_model.har'
runner.save_har(compiled_model_har_path)
Logs:
bird@minipc:~$ python3.10 dfc_script.py
[warning] Cannot use graphviz, so no visualizations will be created
[info] Translation started on ONNX model supercombo
[info] Restored ONNX model supercombo (completion time: 00:00:00.32)
[info] Extracted ONNXRuntime meta-data for Hailo model (completion time: 00:00:01.58)
[info] Simplified ONNX model for a parsing retry attempt (completion time: 00:00:04.27)
File "/home/bird/.local/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/parser/parser.py", line 179, in translate_onnx_model
parsing_results = self._parse_onnx_model_to_hn(onnx_model, valid_net_name, start_node_names,
File "/home/bird/.local/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/parser/parser.py", line 237, in _parse_onnx_model_to_hn
return self.parse_model_to_hn(onnx_model, None, net_name, start_node_names, end_node_names,
File "/home/bird/.local/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/parser/parser.py", line 263, in parse_model_to_hn
File "/home/bird/.local/lib/python3.10/site-packages/hailo_sdk_client/model_translator/translator.py", line 76, in convert_model
self._create_layers()
File "/home/bird/.local/lib/python3.10/site-packages/hailo_sdk_client/model_translator/edge_nn_translator.py", line 28, in _create_layers
self._add_direct_layers()
File "/home/bird/.local/lib/python3.10/site-packages/hailo_sdk_client/model_translator/edge_nn_translator.py", line 138, in _add_direct_layers
raise ParsingWithRecommendationException(
UnexpectedNodeError in op /Unsqueeze_1: Unexpected node /Unsqueeze_1 (Unsqueeze)
UnsupportedReduceMeanLayerError in op /_attention/layer_norm/ReduceMean: Reduce mean layer /_attention/layer_norm/ReduceMean has unsupported axis -1 (must be over one spatial dimension only).
UnsupportedReduceMeanLayerError in op /_mlp/layer_norm/ReduceMean: Reduce mean layer /_mlp/layer_norm/ReduceMean has unsupported axis -1 (must be over one spatial dimension only).
UnsupportedReduceMeanLayerError in op /_attention/layer_norm/ReduceMean_1: Reduce mean layer /_attention/layer_norm/ReduceMean_1 has unsupported axis -1 (must be over one spatial dimension only).
UnsupportedReduceMeanLayerError in op /_mlp/layer_norm/ReduceMean_1: Reduce mean layer /_mlp/layer_norm/ReduceMean_1 has unsupported axis -1 (must be over one spatial dimension only).
UnsupportedFeatureSplitterLayerError in op /_attention/Split: Feature splitter vertex /_attention/Split is splitting input over unsupported axis 2
UnexpectedNodeError in op /Unsqueeze: Unexpected node /Unsqueeze (Unsqueeze)
Please try to parse the model again, using these end node names: /_extra_in/_extra_in.1/Relu, /summarizer/Div
File "/home/bird/dfc_script.py", line 35, in <module>
File "/home/bird/.local/lib/python3.10/site-packages/hailo_sdk_common/states/states.py", line 16, in wrapped_func
File "/home/bird/.local/lib/python3.10/site-packages/hailo_sdk_client/runner/client_runner.py", line 876, in translate_onnx_model
parser.translate_onnx_model(model=model, net_name=net_name, start_node_names=start_node_names,
File "/home/bird/.local/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/parser/parser.py", line 211, in translate_onnx_model
parsing_results = self._parse_onnx_model_to_hn(simplified_model, valid_net_name,
What should i do now, thanks.![]()
