Hello! I am attempting to run the instance_segmentation pipeline and depth pipeline but I am receiving a few errors:
1: .env file not found: /home/sdp/hailo-rpi5-examples/hailo-apps-infra/.env
2: Trying to link elements cropper_wrapper_cropper and inference_scale_q that don’t share a common ancestor: inference_scale_q hasn’t been added to a bin or pipeline, and cropper_wrapper_cropper is in pipeline0
3: gst_element_link_pads_filtered: assertion ‘GST_IS_BIN (parent)’ failed
4: Trying to link elements inference_output_q and cropper_wrapper_agg that don’t share a common ancestor: inference_output_q hasn’t been added to a bin or pipeline, but cropper_wrapper_agg is in pipeline0
Pipeline Code:
# region imports
# Standard library imports
import gi
import os
import setproctitle
from pathlib import Path
import sys
# Local application-specific imports
from hailo_apps.hailo_app_python.core.common.installation_utils import detect_hailo_arch
from hailo_apps.hailo_app_python.core.common.core import get_default_parser, get_resource_path
from hailo_apps.hailo_app_python.core.common.defines import RESOURCES_JSON_DIR_NAME, HAILO_ARCH_KEY, INSTANCE_SEGMENTATION_APP_TITLE, INSTANCE_SEGMENTATION_PIPELINE, RESOURCES_MODELS_DIR_NAME, RESOURCES_SO_DIR_NAME, INSTANCE_SEGMENTATION_MODEL_NAME_H8, INSTANCE_SEGMENTATION_MODEL_NAME_H8L, INSTANCE_SEGMENTATION_POSTPROCESS_SO_FILENAME, INSTANCE_SEGMENTATION_POSTPROCESS_FUNCTION, DEFAULT_LOCAL_RESOURCES_PATH, JSON_FILE_EXTENSION, DEPTH_PIPELINE, DEPTH_POSTPROCESS_SO_FILENAME, DEPTH_POSTPROCESS_FUNCTION, DEPTH_MODEL_NAME
from hailo_apps.hailo_app_python.core.gstreamer.gstreamer_helper_pipelines import SOURCE_PIPELINE, INFERENCE_PIPELINE, INFERENCE_PIPELINE_WRAPPER, TRACKER_PIPELINE, USER_CALLBACK_PIPELINE, CROPPER_PIPELINE, DISPLAY_PIPELINE
from hailo_apps.hailo_app_python.core.gstreamer.gstreamer_app import GStreamerApp, app_callback_class, dummy_callback
# endregion imports
# User GStreamer Application: Instance Segmentation + Depth Estimation
class GStreamerApproachDepthApp(GStreamerApp):
def **init**(self, app_callback, user_data, app_path, parser=None):
if parser is None:
parser = get_default_parser()
super().__init__(parser, user_data)
# Hailo parameters
self.batch_size = 2
self.video_width = 800
self.video_height = 480
# Detect architecture if not provided
if self.options_menu.arch is None:
detected_arch = os.getenv(HAILO_ARCH_KEY, detect_hailo_arch())
if detected_arch is None:
raise ValueError("Could not auto-detect Hailo architecture. Please specify --arch manually.")
self.arch = detected_arch
print(f"Auto-detected Hailo architecture: {self.arch}")
else:
self.arch = self.options_menu.arch
# Set HEF path (string) for segmentation models
if self.options_menu.hef_path:
self.hef_path = str(self.options_menu.hef_path)
else:
# get_resource_path will use RESOURCE_PATH from env
self.hef_path = str(get_resource_path(
pipeline_name=INSTANCE_SEGMENTATION_PIPELINE,
resource_type=RESOURCES_MODELS_DIR_NAME,
self.depth_hef_path = str(get_resource_path(
pipeline_name=DEPTH_PIPELINE,
# Determine which JSON config to use based on HEF filename
hef_name = Path(self.hef_path).name
if INSTANCE_SEGMENTATION_MODEL_NAME_H8 in hef_name:
self.config_file = get_resource_path(INSTANCE_SEGMENTATION_PIPELINE, RESOURCES_JSON_DIR_NAME , (INSTANCE_SEGMENTATION_MODEL_NAME_H8 + JSON_FILE_EXTENSION))
print(f"Using config file: {self.config_file}")
elif INSTANCE_SEGMENTATION_MODEL_NAME_H8L in hef_name:
self.config_file = get_resource_path(INSTANCE_SEGMENTATION_PIPELINE, RESOURCES_JSON_DIR_NAME , (INSTANCE_SEGMENTATION_MODEL_NAME_H8L + JSON_FILE_EXTENSION))
else:
raise ValueError("HEF version not supported; please provide a compatible segmentation HEF or config file.")
# Post-process shared object
self.post_process_so = get_resource_path(INSTANCE_SEGMENTATION_PIPELINE, RESOURCES_SO_DIR_NAME, INSTANCE_SEGMENTATION_POSTPROCESS_SO_FILENAME)
self.post_function_name = INSTANCE_SEGMENTATION_POSTPROCESS_FUNCTION
self.depth_post_process_so = get_resource_path(DEPTH_PIPELINE, RESOURCES_SO_DIR_NAME, DEPTH_POSTPROCESS_SO_FILENAME)
self.depth_post_function_name = DEPTH_POSTPROCESS_FUNCTION
self.post_process_so_cropper = os.path.join(app_path, 'resources/libdetections_cropper.so')
self.cropper_post_function_name = "crop_detections"
# Callback
self.app_callback = app_callback
# Set process title for easy identification
setproctitle.setproctitle("Approach Depth App")
# Build the GStreamer pipeline
self.create_pipeline()
source_pipeline = SOURCE_PIPELINE(video_source=self.video_source,
video_width=self.video_width, video_height=self.video_height,
frame_rate=self.frame_rate, sync=self.sync
infer_pipeline = INFERENCE_PIPELINE(
hef_path=self.hef_path,
post_process_so=self.post_process_so,
post_function_name=self.post_function_name,
batch_size=self.batch_size,
config_json=self.config_file,
infer_pipeline_wrapper = INFERENCE_PIPELINE_WRAPPER(infer_pipeline)
tracker_pipeline = TRACKER_PIPELINE(class_id=1)
depth_pipeline = INFERENCE_PIPELINE(
hef_path=self.depth_hef_path,
post_process_so=self.depth_post_process_so,
post_function_name=self.depth_post_function_name,
#batch_size=self.batch_size,
cropper_pipeline = CROPPER_PIPELINE(
inner_pipeline=(f'{depth_pipeline}'),
so_path=self.post_process_so_cropper,
function_name=self.cropper_post_function_name,
internal_offset=True
user_callback_pipeline = USER_CALLBACK_PIPELINE()
display_pipeline = DISPLAY_PIPELINE(
video_sink=self.video_sink,
sync=self.sync,
show_fps=self.show_fps,
pipeline_string = (
f"{source_pipeline} ! "
f"{infer_pipeline_wrapper} ! "
f"{tracker_pipeline} ! "
f"{cropper_pipeline} ! "
f"{user_callback_pipeline} ! "
f"{display_pipeline}"
print(pipeline_string)
return pipeline_string
def main():
user_data = app_callback_class()
app = GStreamerApproachDepthApp(dummy_callback, user_data)
app.run()
if **name** == “**main**”:
print(“Starting Approach Depth App…”)
main()
Thank you for your help!
