Sir , i have install hailo dataflow compiler successfully and create a custom model using roboflow yolov8 and conver model to onnx using google colab but in converrtion process when i use command hailomz compile yolov8s --ckpt= best.onnx --hw-arch hailo8l --calib-path train/images --classes 4–performance i have error youir model ir_version 10 is higher than the checkers(9) please any one suggest suggestion it argent thank
Hi @iotpbtrap ,
In colab I used this code to change the ir_version of my onnx file:
# Export the model in ONNX format IR_version 9 (adjust IR version if needed)
import onnx
# Load the ONNX model
model = onnx.load("/content/runs/detect/train/weights/best.onnx")
# Change the IR version to 9
model.ir_version = 9
# Save the modified model
onnx.save(model, "/content/runs/detect/train/weights/best9.onnx")
print("Model IR version changed to 9 and saved as best9.onnx")
maybe it also helps for your model.
Thank you so much.
Before trying this solution,
I just tried to cover the onnx with opset==9, but it didn’t work.
But, this solution works for me. it maybe ir_version and opset has different meaning…
Hi @happistday ,
Thanks for pointing this out!
I did a quick search on the official ONNX docs, and here’s a link that explains both ir_version and opset in detail: ONNX Versioning - ONNX 1.18.0 documentation
