I have a project. And the customer is asking if it is possible to use orange pi to connect with AI kit HAILO 13 TOPS or 26 TOPS?
I hope everyone can help !
Thank you so much
Hey @Quan_Le_Minh
Quite a few people in the community have tried using it - you can search for similar discussions in the forum. From what I’ve seen, the best approach is to:
Install the ARM driver and HailoRT from our developer zone
Install the ARM version of tappas-core
If anything doesn’t install properly, you might need to compile from source
Just a heads up - we don’t officially support OrangePi, but it should be possible to get it working with some effort.
Hope this helps!
