Difference between control and compute units
From the Hailo Technology section and the compile step for models, we know that the Hailo-8 has three different types of resources: control, compute and memory. The purpose of memory is clear: store data. I assume the compute unit performs the calculations and the control unit handles the flow of data, schedules calculations, etc.
Is that correct?
Hey @Nils-Oliver,
Yes, your understanding is spot on:
  • Memory resources store data—this includes both the model weights and any intermediate results that get generated while the neural network is processing.
  • Compute resources handle the actual number crunching needed for neural network operations.
  • Control resources (also called Layer Controller Units or LCUs) manage how data flows through the system, schedule operations, and coordinate everything happening on the device.
Hope that helps clarify things!
