I wish to use my webcam in real-time for detection and tracking based on this example : https://github.com/hailo-ai/Hailo-Application-Code-Examples/blob/main/runtime/python/detection_with_tracker/detection_with_tracker.py
, Considering that “supervision” does not allow it, can you please suggest a solution?
To modify your detection script for webcam use:
- Replace
cv2.VideoCapture("video.mp4")withcv2.VideoCapture(0)for live webcam input. - Ensure the loop processes frames in real-time.
Here’s a modified structure:
import cv2
cap = cv2.VideoCapture(0)
if not cap.isOpened():
print("Error: Could not open webcam.")
exit()
cap.set(cv2.CAP_PROP_FRAME_WIDTH, 640)
cap.set(cv2.CAP_PROP_FRAME_HEIGHT, 480)
# Initialize YOLOX model and tracker here
while True:
ret, frame = cap.read()
if not ret:
print("Error: Failed to capture image")
break
detections = yolox_inference(frame) # Replace with actual YOLOX inference
tracked_objects = tracker.update(detections) # Update tracker
for obj in tracked_objects:
bbox = obj.bbox
id = obj.id
cv2.rectangle(frame, (bbox[0], bbox[1]), (bbox[2], bbox[3]), (0, 255, 0), 2)
cv2.putText(frame, f'ID: {id}', (bbox[0], bbox[1] - 10), cv2.FONT_HERSHEY_SIMPLEX, 0.5, (255, 0, 0), 2)
cv2.imshow("Webcam Detection with Tracker", frame)
break
cap.release()
cv2.destroyAllWindows()
This structure should work with the existing detection_with_tracker.py script.
Let me know if you need help integrating specific parts of your code!
Can you explain more.hiw initialisée the model yolo, i’m sorry for this question, because i’m a beginner ![]()
Hey @mAty1901
This is a way to do it :
from hailo_platform import (HEF, VDevice,
FormatType, HailoSchedulingAlgorithm)
from hailo_platform import InferVStreams, InputVStreamParams, OutputVStreamParams, ConfigureParams, HailoStreamInterface
# Load the pre-compiled Hailo model (replace with your path)
model_path = "/path/to/yolox.hef"
# Configure the Hailo device
device = configure.VDevice()
hef = configure.HEF(model_path)
# Load the inference pipeline
network_group = device.configure(hef)
# Initialize the inference stream
inference_vstreams = InferVStreams(network_group)
# Function for YOLOX inference
def yolox_inference(frame):
# Preprocess the frame as needed for YOLOX model (resize, normalization, etc.)
input_data = preprocess(frame)
# Run inference
result = inference_vstreams.infer(input_data)
# Post-process the results (detection bounding boxes)
detections = postprocess(result)
return detections
I would also recommend looking at Hailo-Application-Code-Examples/runtime/python/utils.py at main · hailo-ai/Hailo-Application-Code-Examples · GitHub
But i cantine use hailo sdk client in raspberry
You’re right. I’ve updated the imports, and they’re now working correctly.
thanks for your reply omria,
i tested this code, but i have the following error message
Blockquote
TypeError: InferVStreams.init() missing 2 required positional arguments: ‘input_vstreams_params’ and ‘output_vstreams_params’
Blockquote
I modified the “inference_vstreams” :
Blockquote
inference_vstreams = InferVStreams(network_group, input_vstreams_params, output_vstreams_params)
Blockquote
and I got this error message " ‘InferVStreams’ object has no attribute ‘_infer_pipeline’
Would you please help me to receive video from RTSP source?
How should I change this code?
