I am trying to compile the .har file resulting from optimization process (added and optimized 3 loRA adapters to qwen2_1.5b_intruct.q.har). All the files come from the v5.3.0 version of the DFC, which I am using, except for the compilation.alls file which is used to produce the compilation script file as in the LoRA tutorial. Getting the file from the link in the v5.3.0 manual results in a 404 not found error, same thing using wget and the resource link. I fear that I am getting compilation error for this cause, since I used the v5.2.0 of the same file which was the most recent one available and some fields may not relate
Thank you for letting us know. I can confirm the issue and asked my collagues to fix it.
Thank you, let me know when the fix will be on
Hi, I am having the same issue. Do you already know when the fix will be done?
According to our engineers, there was no change from version 5.2.0. So you can use this file for now:
https://dev-public.hailo.ai/v5.2.0/blob/qwen2_1.5b_instruct_compilation.alls
I asked them to make this official by adding the file to the link in the tutorial. This may take a day or two.
ok thanks, I still can’t figure out why compilation worked without errors using this compilation.alls only if ran by DFC v5.2.0 while with DFC v5.3.0 I get a lot of errors
I did a test run and also had issues during the last step. I asked our engineers to look into it.
Our engineers added the correct file. I just completed a test run of the tutorial successfully. Let me know whether it works for you too.
