Custom YOLOv8s HEF (4 classes) still showing COCO 80 labels in hailo-apps
I am using a custom trained YOLOv8s model (4 classes for garbage classification) converted to format. I am running it on Raspberry Pi 5 using the example..hefhailo-apps
Command used:
Bash
python hailo_apps/python/pipeline_apps/detection/detection.py \
    --input /dev/video0 \
    --hef-path yolov8s.hef \
    --labels-json garbage_labels.json
Issue:
  1. The terminal and video output still seem to follow the COCO 80 classes logic.
  2. In , I noticed the callback is hard-coded for .detection.pylabel == "person"
  3. In , the is hard-coded for .detection_pipeline.pyTRACKER_PIPELINEclass_id=1
Questions:
  1. How can I properly override the default 80-class post-processing configuration to use my 4-class ?garbage_labels.json
  2. Is it mandatory to modify to support multi-class detection for custom models?detection_pipeline.py
Hi @user431 ,
Regarding the callback - It was set to “person” for the sake of example. If you provide different labels - this is the place to alter the logic.
Regarding TRACKER_PIPELINE class_id: -1 will track across all classes.
Please let me know if this answer your questions.
I have updated the callback logic to match my custom labels and set the TRACKER_PIPELINE to class_id=-1 as suggested. However, the issue persists: the labels displayed on the frame and returned by get_label() are still from the COCO 80 set (e.g., showing “person”) instead of my 4 custom classes.
It seems the --labels-json argument is not being correctly applied to the post-processing instance in the GStreamer pipeline.
Could you please clarify:
  • How can I ensure the libyolo_hailortpp_postprocess.so strictly uses my provided JSON for label mapping instead of the default COCO labels?
  • Is there a specific requirement for the JSON format or the HEF metadata to trigger the correct class count (4 classes) in the post-processing stage?
Thank you for your previous advice. I have updated my callback logic and set the tracker to .class_id: -1
I have a follow-up observation: The label mapping is now working correctly in the Python terminal output, but the on-screen (video window) bounding boxes still display the original COCO labels (e.g., “car” instead of “kitchen waste”).
Here is my terminal log: Detection: ID: 0 Raw: car(3) -> kitchen waste Conf: 0.95
How should I solve this problem?
Can you please share relevant code snippets?
# region imports
# Standard library imports
# Third-party imports
import gi
gi.require_version(“Gst”, “1.0”)
import cv2
# Local application-specific imports
import hailo
from gi.repository import Gst
from hailo_apps.python.pipeline_apps.detection.detection_pipeline import GStreamerDetectionApp
from hailo_apps.python.core.common.buffer_utils import (
get_caps_from_pad,
get_numpy_from_buffer,
from hailo_apps.python.core.common.hailo_logger import get_logger
from hailo_apps.python.core.gstreamer.gstreamer_app import app_callback_class
hailo_logger = get_logger(_name_)
# endregion imports
# User-defined class to be used in the callback function
def \__init_\_(self):
    super().\__init_\_()
# Define your custom labels here
# Mapping from COCO labels (default) to your custom classes
MY_LABELS = {
"person": "recyclable waste",      # Class 0
"bicycle": "hazardous waste",      # Class 1
"car": "kitchen waste",            # Class 2
"motorcycle": "other waste",       # Class 3
\# Fallback IDs
0: "recyclable waste",
1: "hazardous waste",
2: "kitchen waste",
3: "other waste"
# User-defined callback function
def app_callback(element, buffer, user_data):
if buffer is None:
    hailo_logger.warning("Received None buffer.")
    return
\# Note: Frame counting is handled automatically by the framework wrapper
frame_idx = user_data.get_count()
string_to_print = f"Frame count: {user_data.get_count()}\\n"
pad = element.get_static_pad("src")
frame = None
detection_count = 0
for detection in detections:
    \# Get raw info for debugging
    raw_label = detection.get_label()
    class_id = -1
    try:
        class_id = detection.get_class_id()
    except AttributeError:
        pass
    \# Smart mapping: try label string first, then class ID
    label = MY_LABELS.get(raw_label, raw_label)
    if label == raw_label and class_id in MY_LABELS:
         label = MY_LABELS\[class_id\]
    \# Filter based on confidence threshold (user requested 0.5)
    if confidence < 0.5:
        continue
    \# Get track ID
    track_id = 0
    track = detection.get_objects_typed(hailo.HAILO_UNIQUE_ID)
    if len(track) == 1:
        track_id = track\[0\].get_id()
    string_to_print += (
        f"Detection: ID: {track_id} Raw: {raw_label}({class_id}) -> {label} Conf: {confidence:.2f}\\n"
    detection_count += 1
    if user_data.use_frame:
         \# Draw detection bounding box and label
         bbox = detection.get_bbox()
         \# bbox coordinates are normalized \[0, 1\], scale to image size
         x_min = max(0, int(bbox.xmin() \* width))
         y_min = max(0, int(bbox.ymin() \* height))
         x_max = min(width, int(bbox.xmax() \* width))
         y_max = min(height, int(bbox.ymax() \* height))
         \# Draw rectangle
         cv2.rectangle(frame, (x_min, y_min), (x_max, y_max), (0, 255, 0), 2)
         \# Draw label
         label_text = f"{label} {confidence:.2f}"
         cv2.putText(
            frame,
            label_text,
            (x_min, y_min - 10),
            cv2.FONT_HERSHEY_SIMPLEX,
            0.5,
            (0, 255, 0),
    cv2.putText(
        frame,
        f"Detections: {detection_count}",
        (10, 30),
        1,
        (0, 255, 0),
        2,
    user_data.set_frame(frame)
print(string_to_print)
return
def main():
hailo_logger.info("Starting Detection App.")
app.run()
if _name_ == “_main_”:
main()
Because the labels have always been things like ‘car’, I can only map the labels. How can I display my own labels on the screen?
  1. Are you using user_data.use_frame?
  2. I suspect there is an issue with the Json file format.
Thank you, the problem has been resolved; it was just that I didn’t use user_data.use_frame.
