I am working on deploying a custom-trained YOLO object detection model on a Raspberry Pi 5 with Hailo AI HAT (Hailo-8).
The model performs correctly on my development machine in both PyTorch (.pt) and ONNX formats, but after converting it to HEF, the detections become incorrect.
System Information
Target device:
Raspberry Pi 5
Hailo AI HAT+ (Hailo-8, 26 TOPS)
Software environment:
Hailo AI Software Suite Docker: 2025-10
DFC version: 3.33.0
HailoRT: 4.23.0
OS: Raspberry Pi OS / Linux
Inference via:
Custom Python scripts
hailo-apps GStreamerDetectionApp pipeline
Model Details
Model type: Custom YOLO-style object detection
Classes: 1 class (product)
Training framework: Ultralytics YOLO
Export pipeline:
model.pt β ONNX β HEF
ONNX export
yolo export model=model.pt format=onnx imgsz=640 simplify=True nms=False
Observed Behavior
1) PyTorch (.pt) inference
Accuracy: >90%
Correct bounding boxes
Correct object locations
2) ONNX inference
Also works correctly
Same bounding boxes as .pt
Using direct resize preprocessing
3) HEF inference on Hailo
Problem:
Incorrect detections
Fragmented small grid-like boxes
Multiple false boxes where only one object exists
Misaligned bounding boxes
Example:
Expected: 1 object detected
HEF output: 3β10 small incorrect boxes
Preprocessing Comparison
ONNX inference preprocessing
Direct resize
Input: 128Γ128
RGB
float32
normalized (0β1)
HEF inference preprocessing (initially)
Letterbox to 640Γ640
UINT8 input
This mismatch was identified and corrected.
Current HEF preprocessing
Direct resize to model input size
Same as ONNX
RGB
Tested both:
UINT8 input
FLOAT32 input
Problem persists.
Output Format Observations
HEF outputs appear in one of two formats:
Case 1: Hailo NMS format
[1, num_classes, num_proposals, 5]
[ymin, xmin, ymax, xmax, score]
Case 2: Raw detection head
Possible format:
[1, 5, N]
[cx, cy, w, h, confidence]
Both parsing approaches were tested.
What I Have Already Tried
Conversion
Different input sizes (320, 640, 1024)
Re-exporting ONNX with:
nms=True
nms=False
Different .alls scripts
Different calibration datasets
Inference
Matching ONNX preprocessing exactly
Testing both:
UINT8 input
FLOAT32 input
Testing:
Custom inference script
Result
ONNX works correctly
HEF consistently produces incorrect detections
Suspected Root Causes
Based on experiments:
Possible issues:
Quantization/calibration mismatch
Incorrect .alls model script
Anchor/stride/post-processing mismatch
Incorrect NMS or decode configuration
Model head not correctly interpreted by DFC
Minimal Reproduction Steps
Train custom YOLO model
Export to ONNX
Convert to HEF using DFC
Run inference on Raspberry Pi 5 with Hailo-8
Observe fragmented/misaligned boxes
Questions
What is the correct conversion flow for custom YOLO models?
How can I verify that anchors/strides are correctly interpreted?
How can I confirm whether the HEF output is:
Raw head output
Post-NMS output
Is there an official recommended .alls template for custom YOLO models?
Could this be caused by calibration dataset issues?
Additional Info Available
I can provide:
ONNX model
HEF file
.alls script
Calibration dataset samples
Raw output tensor dumps
Screenshots of incorrect detections
Expected Behavior
HEF inference should produce:
Same bounding boxes as ONNX
Same detection count
Same object positions
