Hello Hailo Team,
I am trying to perform real-time inference using a Raspberry Pi 5, Hailo-8, and an IMX708 camera.
I have already fine-tuned a MobileNet-based model and successfully converted it into a .hef file.
When I run the example pipelines provided in the Hailo Apps infrastructure, everything works correctly.
For example, the following command runs without any issues:
rpicam-hello -t 0 --post-process-file /usr/share/rpi-camera-assets/hailo_classifier.json
However, when I try to run my custom model, I encounter the following error:
what(): No tensor with name resnet_v1_50/softmax1
Aborted
The command I used is shown below:
rpicam-hello -t 0 --post-process-file /usr/share/rpi-camera-assets/my_inference.json
The contents of the my_inference.json file are as follows:
"rpicam-apps":
"lores":
"width": 224,
"height": 224,
"format": "rgb"
"hailo_classifier":
"hef_file": "/home/mataflow/hailo_models/best_for_rpicam.hef"
"annotate_cv" :
"text": "",
"fg" : 255,
"bg" : 0,
"scale" : 1.0,
"thickness" : 2,
"alpha" : 0.3
Could you please advise how to resolve this issue?
Thank you in advance.
