Could Hailo on RPI5 integrate on PhotonVision Plug_n_Play AprilTag?
I was looking at https://youtu.be/TG9KAa2EGzQ?si=XTj8HdwE-ySVyAU9
Would it be a cool project to integrate Hailo into this Flash_and_Play with AprilTag’s?
Hi @peder,
This looks like a fantastic project - I’ll take a closer look and keep you posted if we decide to add official support for it. In the meantime, if you run into any issues while integrating Hailo into the project, I’d be happy to help out.
After debugging a day with this. And switch to Raspberry PI 4, The PhotonVision worked fine. But again the Hailo needs the RPI5. Unless someone else thought that this was a good use-case, you probably could close this one after 14 days.
