Compilation by ClientRunner.compile() fails
Compilation by ClientRunner.compile() results in error as shown below.
Could anybody tell me how to resolve these?
Compiling yolov8x.onnx
==================================================== Compile
[warning] REQUIRED_FPS is not currently supported for multi context, reverting to MAX_FPS
[error] Mapping Failed (allocation time: 45s)
No successful assignments: concat17 errors:
Agent infeasible by resources sanity.: Memory units capacity exceeded (available: 128, required: 150).
[error] BackendAllocatorException: Compilation failed: No successful assignments: concat17 errors:
Compiling vgg16_Opset16.onnx
[error] Failed to reach fps on following nodes:
fc1 max reached fps: 0 required_fps: 30
