i converted a nanodet model to .hef format with NMS in the model script. however, i want to use class agnostic NMS (not by class). therefore i tried to use bbox_decoding_only in my modelscript and use a custom NMS logic.
but when using the parameter bbox_decoding_only i don’t get any bounding boxes. the exact same pipeline works if i don’t set this parameter.
nms_postprocess('/nms_config.json', meta_arch=yolov8,bbox_decoding_only=True)\n"
my NMS config is:
"nms_scores_th": 0.45,
"nms_iou_th": 0.4,
"image_dims": [
288,
512
"classes": 3,
"regression_length": 11,
"background_removal": false,
"bbox_decoders": [
"name": "bbox_decoder1",
"stride": 8,
"combined_layer": ""
"name": "bbox_decoder2",
"stride": 16,
"name": "bbox_decoder3",
"stride": 32,
Hi @josef.gugglberger,
Could you please check what output do you get from the model? You can check the model with hailortcli parse-hef HEF-PATH.
The outputs of a model with NMS and a model with “BBOX decoding only” are slightly different. If you take a YoloV8 trained on COCO as reference, you will see the following:
Network name: yolov8s/yolov8s
VStream infos:
Input yolov8s/input_layer1 UINT8, NHWC(640x640x3)
Output yolov8s/yolov8_nms_postprocess FLOAT32, NHWC(1x8400x84)
Operation:
Op YOLOV8
Classes: 80
Image height: 640
Image width: 640
Where 8400 is the number of predicted boxes and 84 is the number of features per prediction:
- 4 box coordinates
- 1 confidence score
- 80 class score
Do you get any number as output of the model with decoding, or all zeros?
hi,
thanks for your answer. i was able to fix it with the information from hailortcli:
Network group name: model, Multi Context - Number of contexts: 2
Network name: model/model
VStream infos:
Input model/input_layer1 UINT8, NHWC(288x512x3)
Output model/yolov8_nms_postprocess FLOAT32, NHWC(1x3024x7)
Operation:
Op YOLOV8
Classes: 3
Image height: 288
Image width: 512
i wasn’t realizing that the output changed and was reading the wrong data type (UINT instead of FLOAT32).
PS: i think in your example there should be 4 (box coords.) + 80 (class scores) = 84. your features add up to 85
