Is there a way to run an RNN using Hailo? If not, is there a workaround, such as saving the internal state externally and running it again?
No , for now we mostly work with CNN .
you can open a ticket in the ticketing system ( Salesforce ) and will check if its something we will support in the future .
regards
Thank you for your reply. I look forward to it.
