Summary
I’m having a similar issue to an already existing post which never got a solution so I’m opening another topic here.
I’m having a runtime issue running a PyInstaller executable of a hailo AI application, which is producing this as the main error message..
Fatal Python error: PyThreadState_Get: the function must be called with the GIL held, but the GIL is released (the current Python thread state is NULL)
System
- Hardware: Raspberry Pi 5
- OS: Debian GNU/Linux 12 (bookworm)
- Acceleration: Both Hailo8 and Hailo8L tested
- Model: yolov8s.hef and yolov8n.hef tested
- Packaging Tool: PyInstaller
What Works
Running the application via the Python interpreter
python main.py
All functionality I expect from my application works, including sending serial packets to an Arduino board, requesting images from a camera and putting them into a hailo detection pipeline.
What Fails
After packaging the application with pyinstaller, running the executable no longer provides the expected functionality and outputs this error.
./dist/main/main
*other startup log messages*
Starting GStreamer pipeline...
Auto-detected Hailo architecture: hailo8
Python runtime state: initialized
The culprit is in a derived class of the GStreamerApp. Here is a sample of the code to demonstrate..
def __init__(self):
# Gathers some information and sets some variables
print("this message shows in the output")
self.create_pipeline() # Error occurs here
print("this message does not show in the output")
Although I know where the code breaks, I have no idea why.
What I’ve tried
- Checked for the hailo library in the dist folder. hailo.cython… is present
- Built with two different accelerators and on different machines
- Built different versions of my software, all come back with the same error regarding GIL
Any help I can get with this would be much appreciated, thank you!
