I understand you’re facing an issue with opening the yolov6n.hef file, resulting in a HAILO_OPEN_FILE_FAILURE(13) error. Let’s go through some steps to resolve this, ensuring we consider the latest versions for Raspberry Pi:
First, verify that the yolov6n.hef file exists in the specified path: /home/admin/hailo-rpi5-examples/basic_pipelines/.../resources/yolov6n.hef. If it’s missing, you’ll need to download or regenerate it.
Ensure you’re using the latest compatible versions of HailoRT and the HEF file for Raspberry Pi. You can check the Hailo Developer Zone or contact Hailo support for the most recent compatible versions.
If the file is missing or corrupted, re-download the model zoo or regenerate the HEF file using the latest Dataflow Compiler compatible with Raspberry Pi.
For Raspberry Pi specifically:
Make sure you have the latest Raspberry Pi OS installed and updated.
Update your Hailo SDK for Raspberry Pi to the latest version:
Thank you. I hadthe same error: ‘HAILO_OPEN_FILE_FAILURE(13)’. I resolved it by following your first step. The issue was due to a typo in the .hef filename in my command.
