After installing packages ( sudo apt install hailo-all ) an error is displayed: E: Unable to correct problem, you have held broken packages. I have a 64-bit version and 16 GB of memory.
Hailo requires version 20 of packages, which is not in the repository:
$ apt-cache showpkg hailo-dkms
Package: hailo-dkms
Versions:
4.19.0-1 (/var/lib/apt/lists/archive.raspberrypi.com_debian_dists_bookworm_main_binary-arm64_Packages) (/var/lib/apt/lists/archive.raspberrypi.com_debian_dists_bookworm_main_binary-armhf_Packages) (/var/lib/dpkg/status)
Description Language:
File: /var/lib/apt/lists/archive.raspberrypi.com_debian_dists_bookworm_main_binary-arm64_Packages
MD5: dc6c58c2901423ab40e5a121f54c47ea
4.18.0-2 (/var/lib/apt/lists/archive.raspberrypi.com_debian_dists_bookworm_main_binary-arm64_Packages) (/var/lib/apt/lists/archive.raspberrypi.com_debian_dists_bookworm_main_binary-armhf_Packages)
4.17.0-2 (/var/lib/apt/lists/archive.raspberrypi.com_debian_dists_bookworm_main_binary-arm64_Packages) (/var/lib/apt/lists/archive.raspberrypi.com_debian_dists_bookworm_main_binary-armhf_Packages)
Reverse Depends:
hailo-all,hailo-dkms 4.20.0
Dependencies:
4.19.0-1 - dkms (2 2.1.0.0) hailofw (2 4.19.0)
4.18.0-2 - dkms (2 2.1.0.0) hailofw (2 4.18.0)
4.17.0-2 - dkms (2 2.1.0.0) hailofw (2 4.17.0)
Provides:
4.19.0-1 -
4.18.0-2 -
4.17.0-2 -
Reverse Provides:
