Hi all,
I am using the Python Example for Object Detection and related code, and I was wondering how can I get the quantization offsets to preprocess the image? I see the InferModel class has a subclass with the quant_infos but when I inspect it, it only shows it is type property object and I have no idea how I can access the member.
The Python API documentation mentions it is a list, but I cannot iterate over it.
I already try to set the input type to FLOAT32, but I am wondering if it is doing input/output quantization as I cannot see the code (ig for obvious reasons).
Fyi: I am using a custom model that for business reasons, I cannot disclose. I can say it is a CNN.
Any help is welcome! Have a nice day!
Hi @Isaac_Nunez ,
The scale and zero point can be accessed in the following way:
for input_info in input_vstream_info:
print(input_info)
print("Scale: {}".format(input_info.quant_info.qp_scale))
print("Zero point: {}'\n".format(input_info.quant_info.qp_zp))
print("Outputs")
for output_info in output_vstream_info:
print(output_info)
print("Scale: {}".format(output_info.quant_info.qp_scale))
print("Zero point: {}\n".format(output_info.quant_info.qp_zp))
At runtime, you can set FLOAT32 format to the input/output streams if you want HailoRT to quantize/dequantize the data for you, or you can set integer format otherwise (and you may have to manually scale the data). For example, if you have a normalization layer at the input of the HEF, you typically set the input to UINT8.
