About voltage, current, and temperature monitoring
Hi everyone,
I understand that it is possible to obtain voltage, current, and temperature data from the Hailo-8 M.2 module via API. Could someone please confirm the measurement ranges (e.g., voltage from what V to what V, current from what A to what A, temperature from what ℃ to what ℃) and the resolution (bit depth) for each parameter?
Thanks in advance!
At this time, we don’t publish detailed specifications such as absolute range or resolution. The API is designed for relative thermal monitoring, while thermal protection is managed by HailoRT. Power measurements are primarily intended for model-to-model comparison and for use with the Hailo Integration Tool to help validate thermal solutions.
Thank you for your reply. I understand it.
