I have been struggling for almost 2 weeks to get a custom trained yolox-s model to compile and run on a hailo 8l. I have done my own research and tried using Claude code but still not successful. Following is a summary (with the help of Claude Code)
Questions for Hailo Support
Primary Question
How should YOLOX models with Focus layers be compiled for Hailo-8L?
The Hailo Model Zoo includes YOLOX, so there must be a standard workflow. Are there:
- Special compilation flags needed?
- Required ONNX export settings?
- A recommended way to handle the Focus layer?
Specific Questions
Does the Hailo SDK support YOLOX Focus layers?
- If yes, what’s the correct compilation procedure?
- If no, how should the ONNX be modified?
Is this a known issue with 640×640 input resolution?
- The batch dimension appears to be confused with the spatial dimension (both are 640)
- Would a different input size (e.g., 608×608) avoid this issue?
What ONNX opset version is recommended for YOLOX?
- Currently using opset 11
- Would opset 13 or another version help?
Should we use the CLI compiler instead of Python SDK?
hailo parser onnx --batch-size 1 ... -
Is there a working YOLOX compilation example?
- Specifically for custom-trained models (not just Model Zoo pre-compiled)
- With 3 output heads format
Problem
When compiling a custom YOLOX-S model for Hailo-8L, the resulting HEF expects batch_size=640 instead of batch_size=1, causing inference to fail.
Error Message
[HailoRT] [error] CHECK failed - Memory size of vstream does not match the frame count!
(Expected 786432000, got 1228800)
Analysis:
- Expected: 786,432,000 bytes = 1,228,800 × 640
- Got: 1,228,800 bytes (single frame: 640 × 640 × 3 pixels)
- The HEF is expecting 640 frames instead of 1 frame
Environment
- Hardware: Hailo-8L
- Software: Hailo AI Suite 2025-10 (Docker)
- HailoRT: 4.23.0
- Dataflow Compiler: v3.33.0
- Model Zoo: v2.17.0
- Model: Custom YOLOX-S trained on 4 classes
- Input Shape: [1, 3, 640, 640] (verified correct in ONNX)
Root Cause Analysis
ONNX Model Structure
The ONNX export contains a Focus layer at the network input (nodes 4-30):
- 6 Slice operations that split the input spatially
- 1 Concat operation that combines them
This is standard YOLOX architecture, but it appears to confuse the Hailo SDK’s batch dimension parser.
Evidence
[Node 4] Slice: /backbone/backbone/stem/Slice
Inputs: ['images', ...]
[Node 9] Slice: /backbone/backbone/stem/Slice_1
Inputs: ['/backbone/backbone/stem/Slice_output_0', ...]
[Node 30] Concat: /backbone/backbone/stem/Concat
Inputs: [Slice outputs]
The Hailo compiler appears to misinterpret these Slice operations and treats the spatial dimension (640) as the batch dimension.
Diagnostic Test Results
ONNX Model Verification
$ python3 check_onnx_shape.py models/yolox_s_3concat.onnx
Input shape: [1, 3, 640, 640] ✓ CORRECT
Output shapes:
[1, 80, 80, 9] ✓ CORRECT
[1, 40, 40, 9] ✓ CORRECT
[1, 20, 20, 9] ✓ CORRECT
Hailo HEF Batch Size
$ python3 check_hef_batch_size.py yolox_s_3output.hef
Input shape: (640, 640, 3)
Expected memory: 1,228,800 bytes ✓ Correct for single frame
ACTUAL memory required: 786,432,000 bytes ❌ 640x too large!
Batch=640 Workaround Test
Sending 640 frames at once succeeds:
batch_data = np.stack([frame] * 640, axis=0) # Shape: (640, 640, 640, 3)
output = infer_pipeline.infer(batch_data) # ✓ WORKS!
This confirms the HEF is compiled with batch=640.
Attempted Solutions (All Failed)
1.
Explicit batch_size=1 in compilation
runner.compile(batch_size=1) # Parameter ignored
2.
Explicit net_input_shapes parameter
net_input_shapes = {'images': [1, 3, 640, 640]}
runner.translate_onnx_model(..., net_input_shapes=net_input_shapes) # Still produces batch=640
3.
Auto-detect shape (removed net_input_shapes)
runner.translate_onnx_model(...) # No shape parameter - still batch=640
4.
Correct output node names
Used actual ONNX output names: ['output_stride8', 'output_stride16', 'output_stride32']
Still batch=640.
5.
Disable Focus layer in YOLOX config
self.use_focus = False # In custom_yolox_s.py
# Focus layer still appears in exported ONNX - appears to be in checkpoint weights
